Technika X22/14C-GB-TCD UK - Flicking backlight: How to disable the Protection Link
  • spartantravis
    • Nov 2019
    • 17
    • Italy
    Hi guys
    I have a Technika 22inch tv that has an annoying flicker in the upper corner of the screen. I have figured out that one of the backlight strips is almost gone and is on its last stretch. This tv has 4 back light strips and I will still be able to use it with the other 3 backlights. The problem is the flicker as it is very difficult to watch/play with it.
    The inverter ( LK-IN220413) has 4 connections to the backlight strips. If I remove any one of them, the onboard mosfet detects it as a fault and switches off the entire backlight to protect the tv. A youtuber called MrReeceyburger123 produced a very nice video on the topic for this particular tv where he desolders a certain capacitor that prevents the board from switching off the backlight (link below)
    https://www.youtube.com/watch?v=yjiXmdU4dKs
    Unfortunately my tv uses a slightly different inverter board and with substantially more capacitors/mosfets on it. As I do not wish to randomly remove pieces of the board without knowing what is what, I wanted to ask you guys if you have any suggestions or guidelines on how to proceed.
    I can provide images of the board and part numbers but I cannot find anything useful on the internet about this circuit board apart from where to buy a new one.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Technika X22/14C-GB-TCD UK - Flicking backlight: How to disable the Protection Li
    At your own risk but here is a video
    • nomoresonys
      • 12272
      • U.S.
      I wouldn't want to run a ccfl tv without protection circuit, could burn the house down.
      • spartantravis
        • Nov 2019
        • 17
        • Italy
        I already looked at that video. it is the link I used in the opening post. The inverter board is different on my particular model.
        • R_J
          • Jun 2012
          • 9588
          look at the ic's datasheet and change or disable the protection
          • spartantravis
            • Nov 2019
            • 17
            • Italy
            Datasheets on these components is difficult to find. I cannot find anything on google for the inverter board. do you have suggestions on websites that do not have their databases indexed by google?
            • R_J
              • Jun 2012
              • 9588
              What's the number on the ic? Is'nt it a TL494C?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Not really a good idea to remove protection other than to help serviceing. The TL494 is the driving IC.
                There is some information in the thread TV Repair Reference Library.
                • spartantravis
                  • Nov 2019
                  • 17
                  • Italy
                  I think I may have fixed it without removing the Protection circuit. I identified the problem with the flickering. There was black charring all around the CCFL that was malfunctioning. I am guessing that the bulb was arcing due to degradation of the wire soldering. I resoldered it (with incredible difficulty) and reassemblied the tv. It functions for the time being so I dont need to remove any circuits. The thing is a fire hazard though so if you hear a story about a house burning down due to a Technika TV, ,you can say "I tried to tell you"
                  • nomoresonys
                    • 12272
                    • U.S.
                    Well at least you weren't dumb enough to disable the protection, ccfl run way too hot for that noise.
                    • nomoresonys
                      • 12272
                      • U.S.
                      By that I mean very high voltage compared to led backlighting.
                      • Comp_Pro
                        No Backlight Macbook A1990 820-01041
                        by Comp_Pro
                        Hello all,
                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                        Tests performed:
                        There is no backlight even with a good screen.
                        Backlight IC is receiving the correct support voltages.
                        Fuse F8400 ok
                        Current sense resistor R8400 ok
                        Backlight IC is receiving 3.3V on enable pin.
                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                        Backlight IC receiving 5V from PP5V_G3S
                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                        05-06-2024, 10:23 PM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
                      • Kingfreddie
                        LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                        by Kingfreddie
                        Ok.. this is the story:
                        Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                        This is kinda how it looked, just that mine were at the bottom of the screen:
                        09-11-2021, 01:57 AM
                      • canadaboy25
                        LG Flatron 24EN33TA No Backlight When Cold
                        by canadaboy25
                        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                        03-07-2023, 12:23 AM
                      • Cornito
                        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                        by Cornito
                        Hello Team,
                        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                        08-08-2024, 08:09 AM
