Panasonic tx-50cx802b backlight and sound but no picture
  • sordids999
    • May 2013
    • 2152
    Hi
    Bit stumped with this tv
    Backlights come on and have sound but no picture
    I have even removed each tcon ribbon just to eliminate the screen but nothing
    Tcon fuse 12v both sides
    Psu
    Srv-16v =15.3v
    Srv-5v = 5.0v
    Srv-vcc= 27.6v
    Driver board
    Srv-led =40.7v
    Srv-16v=15v
    Srv-28v=27.4v
  • sordids999
    • May 2013
    • 2152
    Re: Panasonic tx-50cx802b backlight and sound but no picture
    More pics of underside of the psu
    • Hamie
      • Apr 2014
      • 1383
      Testing the tcon would be where I would start.
      Upload a picture so we can see the test points.
      • neilc6
        • Nov 2015
        • 1550
        Panasonics usually have blink codes. I would connect one side of the tv at a time (looks like 2 ribbons per side) to make sure you don't have a bad panel.
        • sordids999
          • May 2013
          • 2152
          Picture uploaded of tcon board
          I have tried removing two ribbons at a time but still nothing shows up on the screen
          thanks
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Is the set giving an error blink code ?
            • Hamie
              • Apr 2014
              • 1383
              Check
              Vgl
              Vgh
              V33
              V12
              • sordids999
                • May 2013
                • 2152
                Thanks hamie I'll check
                Dick barton no errors it flashes green and stays green as if the tv is working fine
                • sordids999
                  • May 2013
                  • 2152
                  This is all I could find on the tcon
                  Vgl 0.35v
                  Vghp 0.00v
                  V12m 0.00v
                  V33dr 0.58v
                  Main tcon fuse 12v
                  • Hamie
                    • Apr 2014
                    • 1383
                    Looks like the tcon may be faulty.
                    Test those voltages again but with the 4 connections to the panel removed.
                    • sordids999
                      • May 2013
                      • 2152
                      I will do thanks
                      Theres a few tcons on Ebay quoted as refurbished and spoken to a seller who's told me the screens are poor on these TVs as well
                        Vgl 0.35v
                        Vghp 0.00v
                        V12m 0.00v
                        V33dr 0.58v
                        Main tcon fuse 12v
                        So do you get the same Voltage readings without all 4 cables between T-CON and the LCD panel?
                        • sordids999
                          • May 2013
                          • 2152
                          Sorry I'm away at the moment I'll check in the morning
                          • sordids999
                            • May 2013
                            • 2152
                            Sorry for the late reply but with all 4 ribbons disconnected it's the same readings
                            • Hamie
                              • Apr 2014
                              • 1383
                              At a guess say UP1 has failed.
                              I know these boards are pretty cheap but would be interesting to know what actually failed.
                              Off chance that the panel may have killed the board so I'd test the new tcon without the panel connected when you first install it.
                              • sordids999
                                • May 2013
                                • 2152
                                Update
                                Tcon arrived today and the tv is now back up and working and testing
                                Thanks for your help
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  Good job
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • DKWS89
                                    Sony XBR 49x900E - Sound and backlight on but no picture
                                    by DKWS89
                                    Hey Guys,
                                    So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                    All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                    12-14-2023, 04:30 PM
