samsung un82mu8000fxza image disappearing
  • superg
    • Dec 2013
    • 58
    • Barbados
    I went to client's office to look at this tv. I didn't open because I don't know where to start. It works for a while and then the picture disappears.The back light stays on and there is no sound or picture. I tested it on youtube.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: samsung un82mu8000fxza image disappearing
    That is a large set and I would be hesitant in opening it up.
    If you can remove the back cover and cool the heatsink over the BGA chip to see if it stays on longer.
    • brucetv
      • May 2015
      • 281
      • united states
      We had one of these beast's in 2 months ago and it turned out to be a bad Main Video board part #BN94-12552R. We had steady backlights and audio but no 12V on Tcon fuse F203. See if you have 12V on both sides of that fuse. If you do turn tv off and disconnect one ribbon cable on the tcon and turn on and see if you see the Samsung Logo screen pull up. This beast has four. Try all four one by one and see if the Samsung logo pull up at all. If the tv does boot up properly with one of those ribbons disconnected you may have a short on the lower driver board for that section. It's usually a bad cap or two on that driver board and a pain to find the short because they are in parallel so you have to remove one itty bitty cap at a time to find it. The MU series has been plagued with this problem.
      • CapLeaker
        Leaking Member
        • 8158
        probably a bga issue on the main IC on the main board.
          • 12196
          • U.S.
          Maybe try heating the mainboard and powerboard with a hairdryer when it fades out, see if it fades back in, heat the electrolytic capacitors first then move around from there.
            09-07-2024, 05:50 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • shlomim412
            samsung ua55es6800 - no image
            by shlomim412
            hi
            having problem with samsung ua55es6800
            tv had backlight on, sound working - responds to the remote control but no image.
            check tcon board - had 12v in but no other voltages present.
            when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
            when leaving only left side connected - again no voltages and no image.
            put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
            kept trying to block less pins on the left ribbon cable...
            05-15-2024, 05:00 AM
