Vizio M50-C1/M65-C1 Service menu
  • xfox
    • Feb 2018
    • 84
    Hello, please help to find a way to get to service menu on Vizio M50-C1/M65-C1, tried everything from google
    • 12323
    • U.S.
    Re: Vizio M50-C1/M65-C1 Service menu
    Not sure if what you want to try will work, need to be very careful in service menu, it's pretty easy to brick a tv in that menu but here's some to try:
    Method 1
    Turn The TV off.
    Press and hold the {CH +} & {CH -} buttons on the TV.
    Then press and release the {POWER} button on the TV.
    Release the {CH +} & {CH -} buttons.
    Now press the {MENU} button on the remote.
    You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
    Press and hold the {MENU} button for few seconds.
    The Service Menu will be displayed.
    Method 2
    Turn The TV off.
    Then press and hold the {POWER} button on the TV.
    Keep all three buttons pressed for few seconds.
    Method 3
    Press and hold the {EXIT} button on the remote for 3 seconds then release it.
    Then press the {1} {2} {3} buttons on the remote.
    To exit, press the {EXIT} button.
    Method 4
    Press the {MENU} {2} {4} {8} {9} buttons on the remote.
    Method 5
    Press the {MENU} {1} {2} {3} buttons on the remote.
    • xfox
      • Feb 2018
      • 84
      Method 1
      Turn The TV off.
      Method 2
      Turn The TV off.
      Method 3
      Method 4
      Method 5
      Tried 3-5 not working, 1-2 - there is no CH+/- on TV, only input VOL+ VOL- and POWER
      • budwich
        • Jul 2015
        • 3097
        why do you need to get into the service menu?
          • 12323
          • U.S.
          Another to try:
          Turn off your TV but leave it plugged in.
          Hold down both the “CH+” and the “CH-” buttons on the TV remote.
          Press and release the “Power” button on the TV remote.
          Let go of the “CH+” and “CH-” buttons.
          Press the “Menu” button on the TV remote.
          The TV should turn on and present you with the menu. You should see an “F” in the bottom right to indicate this is a factory setup screen.
          Press and hold the “Menu” button for a few seconds.
          You should see the Service Menu.
          • xfox
            • Feb 2018
            • 84
            As I said I used main board from M50-C1 on M65-C1 (twice cheaper), but was able to start it with rewriting EEPROM (different tcon, and led driver), after eeprom replacement tv starts and I can use it, but after restart eeprom get overwritten so I need to change TV model number, to keep settings in place, I did that trick for samsung already, maybe will work for vizio.
            • xfox
              • Feb 2018
              • 84
              Another to try:
              When I hold down “CH+” and the “CH-” remote stop sending signals (checked with phone camera) so pressing power will not turn on tv
                • 12323
                • U.S.
                Lots of reports about difficulty getting into service menu on these, thinking there must be a way tho, how else can they be put in hotel mode and such??
                • xfox
                  • Feb 2018
                  • 84
                  Vizio support said they do not have any service code ) So for now hopeless
                  • R_J
                    • 9628
                    Try this:
                    Do the following steps rapidly:
                    1. Press “MENU”;
                    2. Press”1”+”9” +”9” +”9”;
                    3. Press ”last”;
                    • xfox
                      • Feb 2018
                      • 84
                      Damn, worked, so one dude from Vizio support gave correct one but forgot about return after 1999, unfortunately that menu cannot change model number, so I assume they flashed it to emmc and it's specific per model
                        • 12323
                        • U.S.
                        I thought that "no service code" was BS from vizio, looks like the one guy was close then the second had no clue so he said there isn't one, too funny.
                          • 12323
                          • U.S.
                          Should prolly stick that service code procedure up in Randtek's factory reset sticky.
                          • RRice25541
                            • Nov 2015
                            • 47
                            ok so i realize this post is quite old but i have solution to this Vizio board swap problem and the eeprom being overwritten when the TV is turned off and back on again.
                            I had the same issue with a M50-C1
                            I didn't want to purchase an exact replacement because at the time i didn't know if the TV had other issues or not.
                            I did however have a D50-D1 Main board.. when i installed it as-is the screen was stretched out...so i copied the code from the M50 to the D50 Main board and then used my programmer to bit protect the code from being overwritten if the TV was turned off and back on..
                            you need lock out(protect) BP0,BP1,BP2,BP3 after you've copied your code into the replacement boards eeprom..
                            this may however keep the TV from ever receiving any updates lol but the TV should not have the above issue any longer
                              LCD LED TV Service Menu Codes
                              ALL LCD LED TV SERVICE MENU CODES
                              Service Menu Code with Board Name
                              China Universal Board / Jumper Board Service Menu Code
                              Changhong Ruba Service Menu Code
                              Ecostar LED TV Service Menu Code
                              Orient LED TV Service Menu Code
                              Haier LED TV Service Menu Code
                              TCL LED TV Service Menu Code
                              Samsung LED TV Service Menu Code
                              LG LED TV Service Menu Code
                              Videocon LED TV Service Menu Code
                              Supra LED TV Service Menu Code
                              Toshiba LED TV Service Menu Code
                              Symphony LED TV Service Menu Code
                              Veste/ LED TV Service Menu Code...
                              10-31-2024, 03:58 AM
                            • tusiime
                              How to access Vizio m652i-b2 service menu
                              by tusiime
                              The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                              So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                              Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                              09-15-2023, 09:57 AM
                            • JaquesPratt
                              Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                              by JaquesPratt
                              I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                              This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                              07-16-2024, 01:04 AM
                            • ARGO
                              Vizio service menu code
                              by ARGO
                              There are a lot of different codes on internet but they doesn't work for all modern Vizio TVs.
                              Here is tested code to enter service menu (factory menu), tested by me on D-series and P-series:
                              MENU-1-9-9-9-Return.
                              (Retun is a button with round arrow on remote)
                              Overall the menu is useless because it doesn't allow to change panel and LVDS settings...
                              If anybody knows any other codes for Vizio, post it here, please.
                              By the way, Philips TVs uses the same main boards with same service menu access code......
                              06-10-2020, 08:16 PM
