LG 42ln5300-UB won’t turn on and only has standby voltage
  • NickIsFluffy
    • Apr 2020
    • 23
    Re: LG 42ln5300-UB won't turn on and only has standby voltage
    Originally posted by budm
    You still did not perform the test as requested in post #21, #31. You are not doing what we are requesting to help troubleshooting the problem. We are up to 39 posts now and still no result for us to see.
    If we think logically my mainboard and powerboard doesnt not have an issue. I already said that we replaced the mainboard and the power supply board. so it shouldnt be an issue.
    • NickIsFluffy
      • Apr 2020
      • 23
      My next suspicion is that this standby LED card may have something to do with it because when I press the on button on the control buttons, it's supposed to give a signal to the main board to do whatever you are telling it to do. But that's not happening and neither is there a standby LED
        P201 is the connector where you had tested the 12V, 24V, PWR-ON earlier, make sure to count the pins correctly. Make sure to count the pins correctly, the black dot is pin 1, the exposed pins that you can see from the top of the board are the EVEN number pins, to get to the EVEN number pins you will have to probe from the backside (this is harder to do because you have to flip the board over and the power is apply, more chance of shorting things out) of the board or probe at the wire entrance of the connector. BTW, all the connectors have to be put in place for this test.
          So you are 100% sure that those two board are perfectly good boards and no way the used boards can be bad? We are trying to verify them by checking the Voltages. Good luck figuring out, I am out.
          You say the new boards have no issue but yet you are not getting the PWR-ON to turn on the rest of the power supplies. Is that logical that there is problem??? Right now we have no idea what control signals you have or do not have from the main board when power switch is toggle on and off.
          You can keep throwing in new boards at it and hoping it will fix the problem or perform troubleshooting step by step..
          Your post # 12"
          Quote:
          Originally Posted by R_J View Post
          The board outputs for a (42") 157.5v/ 341ma I agree he has an open led string.
          You use a meter to check the voltage on the PWR-ON pin when you push the power switch.
          When I test it, it just shows 0.
          • nomoresonys
            • 12330
            • U.S.
            #45
            FFS, just buy a new tv, I'm afraid you will be 150 years old before you fix this one, you need a little competence to work on electronics, There are DEADLY voltages that I don't think you should be around. Give this tv to someone who can fix it...and just let it go.
            • NickIsFluffy
              • Apr 2020
              • 23
              Your post # 12"
              correct, the boards are perfectly fine
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • maxim2511
                LG 55EC930V OLED - swich on swich of no screen
                by maxim2511
                My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                Then I get an idea to take it apart and clean boards from dust.
                In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                05-14-2021, 02:21 AM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
