LG 42ln5300-UB won’t turn on and only has standby voltage
    Re: LG 42ln5300-UB won't turn on and only has standby voltage
    Quote:
    Originally Posted by R_J View Post
    The board outputs for a (42") 157.5v/ 341ma I agree he has an open led string.
    You use a meter to check the voltage on the PWR-ON pin when you push the power switch.
    When I test it, it just shows 0.
    Are you saying if you keep the meter probe on PWR-ON pin it does not change state when you toggle TV on and OFF? How about DRV-ON, does it also change state when TV is turned on and off? Do you also get the same result doing this same test on the old boards?
    • NickIsFluffy
      • Apr 2020
      • 23
      Oh I haven't tried that yet. I just turned the tv on and then put the probe on the power on, I haven't tried DRV-ON yet, what does it mean?
      • NickIsFluffy
        • Apr 2020
        • 23
        Originally posted by dick_barton
        You said in an earlier post that the led voltage was 200V. The photo you posted shows that a 42 inch set has a led voltage of 157.5V.
        It looks as though you have an open circuit led(s) which is why the set appears not to be powering up. The over voltage protection is probably kicking in and powering down the power supply.
        I wasn't exactly sure how much, it wasn't 200v tho, I didn't meant to exaggerate but now that I'm thinking about it, I think it was around 120-150v or something, but if so how could I fix the issue, cuz I replaced the main board and the power supply board.
          If PWR-ON is 0V then the rest of the power supplies and the PFC will not be turned on, so without PFC the then the backlight boost converter for the LED drive circuit will not be working either. You better make sure you are testing the Voltage correctly.
          • NickIsFluffy
            • Apr 2020
            • 23
            so what voltages am I expected to get?
            • NickIsFluffy
              • Apr 2020
              • 23
              how can I fix that?
                It should toggle between <1 (TV OFF), and >2v (TV ON).
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  how can I fix that?
                  Carry out the checks as asked for by the other forum helpers. This helps to provide a better diagnosis of the fault and less guess work on our part. Remeber we don't have the set in front of us.
                  • nomoresonys
                    • 12330
                    • U.S.
                    #29
                    carry out the checks as asked for by the other forum helpers. This helps to provide a better diagnosis of the fault and less guess work on our part. Remeber we don't have the set in front of us.
                    +1000
                    • NickIsFluffy
                      • Apr 2020
                      • 23
                      I just checked the LEDS, and I was getting around 157v, and then I checked the power on and off, and it was at 0v.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #31
                        Measure the dc voltages at all the pins of P201 when in standby and when you attempt to bring it out of standby.
                        Code:
                        Pin  Name    Standby  Out of standby
                        1   Power On  xx       xx
                        2   DRV_On   yy       yy
                        19   GND     zz       zz
                        Do you have 24V across C203
                        • nomoresonys
                          • 12330
                          • U.S.
                          #32
                          Seems like a mainboard or cable from power to mainboard issue with those key voltages missing, you can't just match mainboards by the tv model. Check that the alphanumeric digits on the white stickers of both mainboards match and don't be afraid to do the tests like Dick said.
                          • NickIsFluffy
                            • Apr 2020
                            • 23
                            Yeah must be the cable, because I already replaced the mainboard and power supply board, but I still dont understand why I was only getting the standby voltage.
                            • nomoresonys
                              • 12330
                              • U.S.
                              #34
                              Easy enough to check continuity from end to end on each terminal of connector, so DID the alphanumeric string on white stickers match on both mainboards??
                              • nomoresonys
                                • 12330
                                • U.S.
                                #35
                                need to do tests and answer questions as they come or everything just gets all mixed up, did you check the solder joints of the connector??
                                • NickIsFluffy
                                  • Apr 2020
                                  • 23
                                  Yes, I checked it all, the numbers and made sure the boards were all right, the only thing I was was that one of the pins were bent a little, where you insert the cable from the power supply board to the main board, but that was an easy fix, I just unbent the pin and it was all good.
                                  • nomoresonys
                                    • 12330
                                    • U.S.
                                    #37
                                    Can try a force on of powerboard, follow closely, unhook cable from powerboard to mainboard at powerboard side, jumper about a 1k resistor from PWR_ON pin to 3.5 standby pin now use another 1k resistor from standby to DRV_ON and another resistor from standby to PDIM, plug power cord into powerboard, now do you have those missing 12 and 24 or whatever was missing and do backlights come on and stay on??
                                    • NickIsFluffy
                                      • Apr 2020
                                      • 23
                                      I dont have any resistors on hand. I tested the bottom Front LED thats supposed to show the red light. There seemed to be no problem, but the LEDs dont work, the red one at the bottom near the stand. I tested all the cables and nothing seemed to be wrong with them. Im not sure what else to test, my next idea is that maybe theres something wrong with the control buttons on the tv, becuase I don't have the remote. I havent tested the LED backlights yet.
                                        You still did not perform the test as requested in post #21, #31. You are not doing what we are requesting to help troubleshooting the problem. We are up to 39 posts now and still no result for us to see.
                                        • NickIsFluffy
                                          • Apr 2020
                                          • 23
                                          I dont understand what p201 and the other thing is on post #31
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
