LG 42ln5300-UB won’t turn on and only has standby voltage
  • NickIsFluffy
    • Apr 2020
    • 23
    Sorry for the multiple threads in different forums, I didn't quite know which forum to post this in, but I got some help, once again im really sorry about the multiple posts. But back to the title;
    I have this LG 42ln5300-UB tv, but it won't turn on, there's only 3.3v standby but its supposed to have 3.5v on the power supply board. We already replaced the main board and the power supply board, but it didn't make a difference, I still only had that 3.3v standby. We are missing the remote for the tv, if that makes a difference. How can I fix this issue, I've already gone through all the trouble to buy a new part so i'm determined to fix the issue.
  • nomoresonys
    • 12328
    • U.S.
    Re: LG 42ln5300-UB won't turn on and only has standby voltage
    Post some good clear straight on pictures of each board and one of the whole back so we can see how they are connected, for pictures just hit go advanced and manage attachments, try test number 3 below, report voltages.
    • NickIsFluffy
      • Apr 2020
      • 23
      I already said that I replaced the Main board AND the Power Supply board, but was still getting only a standby voltage, the red light at the bottom doesnt show anything, when I plug the tv in, it just stands there, not light, no picture, no sound, no nothing.
      • neilc6
        • Nov 2015
        • 1550
        With LN series, bad backlights are the most common failure. Does the tv turn on but with no backlight? 3.3V vs 3.5V is not an issue. If the tv responds to the on/off button and the backlights don't come on, they will be your main suspect.
        • NickIsFluffy
          • Apr 2020
          • 23
          Nothing happens, And on the power supply I should be seeing 12v and 24v, but nothing is shown exept for the almost 200v LED+ pin.
          • NickIsFluffy
            • Apr 2020
            • 23
            An I don't know how I can check that the TV responds to the On/Off button, if its the LEDs how do I know that the On/Off is responsive
            • nomoresonys
              • 12328
              • U.S.
              Were the boards that you ALREADY REPLACED NEW??? NO??? that's why we do the tests, got it???
              • nomoresonys
                • 12328
                • U.S.
                You won't get much help if you can't follow simple directions AND all you have to offer is ATTITUDE.
                • NickIsFluffy
                  • Apr 2020
                  • 23
                  Ok
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Can you post a picture of this box. If you have 200V at the led, then I suspect you probably have a led problem.
                    • R_J
                      • Jun 2012
                      • 9623
                      The board outputs for a (42") 157.5v/ 341ma I agree he has an open led string.
                      You use a meter to check the voltage on the PWR-ON pin when you push the power switch.
                      • NickIsFluffy
                        • Apr 2020
                        • 23
                        When I test it, it just shows 0.
                        • NickIsFluffy
                          • Apr 2020
                          • 23
                          Yeah I attached it
                          • handsworth
                            • Oct 2015
                            • 174
                            More than likely its the leds, however just a side note. When buying these tvs for repair, I have found out that the PO for some reason had turned the standby light off from the settings. Also in some cases the tv speaker was set to external or optical. Just something to consider.
                            • NickIsFluffy
                              • Apr 2020
                              • 23
                              so whould I have to open the full metal back panel to check out the LEDs? also if its the LEDs, wouldnt the red light be at the bottom? because I dont see it.
                              • R_J
                                • Jun 2012
                                • 9623
                                If you are getting 3.5v and also the 200v at the led's, this power supply is working.
                                • NickIsFluffy
                                  • Apr 2020
                                  • 23
                                  But im not getting the other 12v or 24v
                                  • R_J
                                    • Jun 2012
                                    • 9623
                                    This is an always on power supply, the only reason you are not seeing +24 volts at the connector is because Q201 is not turned on. If you check the cathode of ZD201 you will find the +24v source (which will check higher)
                                    • NickIsFluffy
                                      • Apr 2020
                                      • 23
                                      Sorry I dont know what the Q201 is and the cathode of ZD201, can u help me out?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        You said in an earlier post that the led voltage was 200V. The photo you posted shows that a 42 inch set has a led voltage of 157.5V.
                                        It looks as though you have an open circuit led(s) which is why the set appears not to be powering up. The over voltage protection is probably kicking in and powering down the power supply.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
