Toshiba 50L7300A turns on then blue screen
  • Woollyentity
    • Apr 2020
    • 12
    I have a second hand Toshiba 50L7300A which, when plugged in, turns on and displays the Red Toshiba logo, but then displays a bright blue screen.
    I understand this may be a problem with the main board (32L4300 rev 1.02a) but I'm not sure, and they're very difficult to find now anyway.
    I tried updating the firmware - the USB flashes a few times when plugged in, then nothing happens and the blue screen is still all I get.
    I also have no remote for this TV.
    Video of the problem:
    imgur.com/a/wdqRLEI
    If you've heard of anything similar please let me know what I can try.
  • R_J
    • 9515
    Re: Toshiba 50L7300A turns on then blue screen
    I suspect it is a bga problem on the large ic, try heating it with a hot air gun and see if that helps.
    • notallbad
      • Oct 2012
      • 1183
      what process are you using to update the fw?
      where was the fw from and what is it named and how big is the file.
      Sounds like what my blaupunkt is doing after I buggered the fw settings, see my most recent post.
      logo. bluescreen, unresponsive to remote and keypad, turns off after 1 minute
      can you get the nenu to appear if really quick after the logo goes off???
      • Woollyentity
        • Apr 2020
        • 12
        Maybe I'll try that
        • Woollyentity
          • Apr 2020
          • 12
          fw downloaded from a site I found it on, can't remember which site but the download came with instructions as well. The version is v7.1.68.07.01.1. The instructions seem to have been issued by Toshiba so I followed them. Basically just formatted a USB, then put the .fwu file on it. Then I powered the TV off, inserted the USB, pressed and held volume down button, powered the TV back on, at which point the upgrade was supposed to automatically begin on the screen, which it didn't.
          Haven't tried that. As I said I have no remote but I can try the button on the TV?
          • notallbad
            • Oct 2012
            • 1183
            Perhaps. forget about fw upgrade for the time being, you could be getting yourself into deeper waters.
            The usb flashing a couple a couple of times from power on is normal, try it with a blank usb stick, probably results will be the same! It is possible your supposed to hold vol down or press '0' on the remote whilst powering it up whilst usb with fw is in the usb port.
            I'm guessing the tv was in this condition when you got it so you don't know the history, possibly it was a fw upgrade that broke it???
            Check all voltages on the power board, if you have no meter or not confident enough just disconnect the backlight power connector to see if tv remains on and responsive to keypad
            then you could also try disconnecting the t-con for comparitive results
            (always connect / disconnect with power OFF! and after 20-30 secs to allow residual power to dissipate first)
            Get yourself a usb-uart device, about £4, to see if you can at least get a response from the tv using putty or similar terminal on your pc
            • Woollyentity
              • Apr 2020
              • 12
              Yeah the TV was like this already.
              I have a multimeter and I'd like to learn to be able to check voltages but definitely not completely confident at the moment.
              I could try disconnecting the backlight although the TV hasn't been responsive to anything and I have no remote.
              Is the T-con the other of the three largest PCBs after the main and power boards?
              Also never heard of the USB-UART but interesting.
              I only intend on using the TV as a big monitor to watch movies played on my laptop anyway. Not sure if that changes much. I appreciate all the help though, I'll let you know once I've had a chance to try some of this.
                • 12081
                • U.S.
                Try test #3 below, try to do it just as instructed, #2 is a video demonstration of testing.
                • notallbad
                  • Oct 2012
                  • 1183
                  Better to remove the rear panel and take photos of the boards and post them here.
                    • 12081
                    • U.S.
                    Be VERY CAREFUL when working on the HOT/DEADLY side of the powerboard.
                    • Woollyentity
                      • Apr 2020
                      • 12
                      Tried it, held it down, pressed rapidly, at different intervals, startup happens the exact same as in original vid. I was using the button under the volume buttons, not even sure what that is but I assumed it had the most to do with this. Also the top power button doesn't work at all so is it possible the buttons just aren't connected at all?
                      Removed the rear panel and took a bunch of photos.
                      https://imgur.com/a/dLyCKcg
                      Couple of reminders:
                      - I have no remote
                      - Haven't had any response from the TV whatsoever other than the original video when I plug the TV in
                      - Power off button on the TV itself doesn't work either, could all the buttons just be disconnected?
                      Thanks again for all your help. If the photos don't reveal anything interesting I'll see about some of the testing methods you guys are talking about
                      • notallbad
                        • Oct 2012
                        • 1183
                        Your 'mystery' board is a wireless card so you can forget about that one and associated cables during testing.
                        The board at the top left is the led driver board.
                        You know which one is the power board, looks good from photos, nothing obvious I don't think. I'm assuming thats just glue around the capacitors (largish cyclindrical shaped with markings like uF and V) holding them to the board and there not leaking. Cant see any bulging!
                        And of course your main board to the right.
                        There will be another board under the metal shield at the bottom, this is the T-con which drives the display panel. Its under the tv stand mounting plate. Add another photo of this board.
                        On the main board there are 3 cables on the top left corner, the middle one looks like its not properly seated?
                        Whilst your at it check all other connectors are seated properly
                        On the keypad its power on / off at the top, then vol up, then vol down, then last one is for 'input source' (short press) AND 'menu' select (long press) The vol buttons are then also used for navigating the menu options and the source/input button used to select the option.
                        Also list the board part numbers and the panel label etc.. not visible from photos.
                        • PopescuFanel
                          • Apr 2019
                          • România
                          I assure you it is a FW problem. I had the same symptoms in another Toshiba model.
                          Make sure the FW belongs to the model, do not update with the wrong FW !
                          • notallbad
                            • Oct 2012
                            • 1183
                            Yh, I'm convinced its fw too, hence recommending not to do a fw update until we can establish board and panel details.
                              • 12081
                              • U.S.
                              That should be the firmware if there's instructions try to follow them exactly: https://support.dynabook.com/support...ext=1200016427
                              • Woollyentity
                                • Apr 2020
                                • 12
                                Yeah power board looks fine visually, that is glue under the capacitors, nothing obviously out of place.
                                Checked the connectors too, all seem to be seated properly.
                                Additional photos here, including T-Con and back panel info:
                                https://imgur.com/gallery/OrchEsT
                                List of details:
                                TV Model - 50L7300A
                                Power board - N255A001L (or "N12-225P1A"? Visible under barcode in photo of PB)
                                Main board - 32L4300 Rev: 1.02A
                                LED Driver board - L50086-2EA
                                T-Con board - V420HK1-CS5
                                @nomoresonys that's the same FW I've already tried, version and all. Maybe I was doing something wrong, we'll see.
                                  • 12081
                                  • U.S.
                                  Try another thumb drive if you have one, sometimes they are not compatible.
                                  • notallbad
                                    • Oct 2012
                                    • 1183
                                    Also remember to format the usb stick first, fat32.
                                    And be sure the fw file is the only file on the stick in the root i.e not in a folder.
                                    Might sound silly but is it a .zip file you have that needs unzipping first?
                                    • Woollyentity
                                      • Apr 2020
                                      • 12
                                      Is exFAT okay? I googled and apparently it encompasses FAT32 and others or something.
                                      Otherwise I can try a different flash drive.
                                      I assume the single file in question is the .fwu file also
                                        • 12081
                                        • U.S.
                                        Sure, try another flash drive.
                                        • Woollyentity
                                          by Woollyentity
                                          imgur.com/a/wdqRLEI
                                          If you've heard of anything similar please...
                                          04-12-2020, 04:00 AM
                                          09-06-2024, 05:27 AM
                                        • Rav_tangle
                                          MacBook Pro 2011 turns on with keyboard light , screen dead
                                          by Rav_tangle
                                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                          is this...
                                          05-31-2024, 04:09 PM
                                        • krige
                                          asus g750js ms1130c (203) turns on nothing on the screen
                                          by krige
                                          hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
                                          03-22-2024, 04:59 AM
                                          09-06-2024, 05:59 AM
