Toshiba 50L7300A turns on then blue screen
  • Woollyentity
    • Apr 2020
    • 12
    I have a second hand Toshiba 50L7300A which, when plugged in, turns on and displays the Red Toshiba logo, but then displays a bright blue screen.
    I understand this may be a problem with the main board (32L4300 rev 1.02a) but I'm not sure, and they're very difficult to find now anyway.
    I tried updating the firmware - the USB flashes a few times when plugged in, then nothing happens and the blue screen is still all I get.
    I also have no remote for this TV.
    Video of the problem:
    imgur.com/a/wdqRLEI
    If you've heard of anything similar please let me know what I can try.
  • nomoresonys
    • 12276
    • U.S.
    Re: Toshiba 50L7300A turns on then blue screen
    Upload the pictures here, make them clear straight on of each board and one of the whole back so we can see how they are all connected, hit the go advanced and follow for procedure.
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      09-24-2025, 10:59 AM
      09-06-2024, 05:27 AM
    • Rav_tangle
      MacBook Pro 2011 turns on with keyboard light , screen dead
      by Rav_tangle
      Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
      I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
      Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
      is this...
      05-31-2024, 04:09 PM
    • sigmeyer
      Toshiba 50UL4B63DG faulty screen?
      by sigmeyer
      I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
      08-30-2025, 08:13 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
