VIZIO M70-C3 Power Supply?
  • CaptGB
    • Apr 2020
    • 10
    No Back Light, No Sound, No Video The board and red light on the CPU audio out tries to power about a minute. Not sure if it the power supply is the problem. Attached photos of voltages at Power Supply board when powered up and then turned on.
    Any Suggestions Welcome.
    • 12276
    • U.S.
    Re: VIZIO M70-C3 Power Supply?
    Looks like your not getting the PS-ON signal from the mainboard.
    • CaptGB
      • Apr 2020
      • 10
      I wasn't sure about the voltages that i was reading -- some looked higher that the board indicated?
      • budwich
        • Jul 2015
        • 3097
        you need to measure and record every pin shown in first picture.... with tv off and then tv on... note some change quickly after pressing on so you have to monitor each one during each press on.
        • CaptGB
          • Apr 2020
          • 10
          I will re check and follow up
          • CaptGB
            • Apr 2020
            • 10
            I do have 5.1 v to PS-ON pin 3 first photo on everything else is correct on the first photos
            Anything else I need to look at ???
              • 12276
              • U.S.
              Easy test, with tv unplugged from power, check all the diodes on powerboard, try diode mode, should get a reading in one direction, reverse meter probes, should read 1 or OL if any read off, take out of circuit and test again.
              • ngth82
                • Jul 2015
                • 541
                Some of the values that you read indicate "33.8" -- is that in VOLTS or MILLIVOLTS?
                -Thomas
                I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                • budwich
                  • Jul 2015
                  • 3097
                  You need to check all the pins as print on the board of the first picture and watched closely during power up. You are saying you never see the tcon on signal?
                  unplug the power cable to the tcon... attempt a power up and check the pins for the 12v.
                  • CaptGB
                    • Apr 2020
                    • 10
                    No dc voltage to tcon pin 13 tcon, 14 tcon or 15 Tcon ON when unpluged and applying power to power supply board.
                    All diode visible on power supply board ck ok
                    All volts checked dc volts
                    • neilc6
                      • Nov 2015
                      • 1550
                      Does look like tcon on signal is missing. Vizio M series have bga failures on the main boards. Try heating up the main board with a hair dryer and see if it turns on.
                      • CaptGB
                        • Apr 2020
                        • 10
                        I am not getting 12V to any of the T Con pins. I'm not sure if it's the Power supply or Main Board. Does the Power Supply receive a signal back to the Main board to power up T Con???
                        • R_J
                          • 9588
                          You will not have any 12V T CON (pins13,4) untill it is turned on by (pin15) T CON_ON
                          You have +12v on pins 8&9 so the power supply is working.
                          Does pin3, PS-ON change when the power button is pressed? if it does not, then the main board is likely the problem.
                          • CaptGB
                            • Apr 2020
                            • 10
                            I do get 5.1v at PS on when the power button is pressed and red led on main board comes on for a while then flashes about 16 times and shuts down
                            (sorry I missed writing it down on the top photo)
                            • R_J
                              • 9588
                              So in standby, PS-ON is 0 volts and when you press the power button, PS-ON goes to 5v correct?
                              • CaptGB
                                • Apr 2020
                                • 10
                                yes correct
                                • R_J
                                  • 9588
                                  So the main board is partly working, it understands the the command from the power button and outputs the PS-ON signal correctly, but it's not outputing the T-CON_ON signal, This could be a bga fault on the main as suggested. It could be that the t-con is not turned on until the backlights are turned on.
                                  So the power supply is working corrctly. I would suspect the main board, you can try heating the large ic under the heatsink and see if the tv comes on. the heating can sometimes temporarly restore the connection.
                                  • CaptGB
                                    • Apr 2020
                                    • 10
                                    tks for the help!!!
                                    • xcctt
                                      • Apr 2020
                                      Does this heating lead one to do an additional re-soldering on a specific part of the board or is this a temporary band-aid that has to be done from time to time and that's all she wrote?
                                      • R_J
                                        • 9588
                                        This heating is on a the large BGA ic, if it works, it just rules out the rest of the tv, but usually is only temporary, to do a proper job the ic needs to be removed, reballed and replaced.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • shovenose
                                          Christmas Light Power Supply Question
                                          by shovenose
                                          I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                                          Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                                          12-08-2023, 09:59 AM
