VIZIO M70-C3 Power Supply?
  • TroutCaptain
    • Jan 2022
    • 13
    Re: VIZIO M70-C3 Power Supply?
    Originally posted by CaptGB
    tks for the help!!!
    Have the exact same issues and voltages you were reporting. Did you ever come up with a fix? Thx
    • Storyteller12
      • Jun 2020
      • 624
      It’s the main board. Specifically the BGA Chips under the heat sink.
      This is a known issue as mentioned with a lot of Vizio TVs.
      • TroutCaptain
        • Jan 2022
        • 13
        Ok thanks for the response. I did try heating with a heat gun without taking off the heat sink but I may need to go at it again with taking heat sink off. Might get better results. Thanks again
        • NZuercher
          • Jan 2023
          I am having the same issue. PS_On has 5 volts and there is 34 V going to the LED board. But, TCon ON has 0 Volts and no power to the TCon board. I already replaced the main board and there was no change...exact same symptoms.
          While there is power to the LED board, I cannot tell if the backlights are actually on or not. Is it possible a bad LED board will keep the main board from turning on the TCon? Or, is it possible the main board is sensing an error on the TCon board and is therefore not turning it on? Or, is it likely that I received a bad main board that happened to have the exact same issue as my original?
          • Storyteller12
            • Jun 2020
            • 624
            Where did you buy the main board from? Sounds like they sent you a defective one possibly
            • NZuercher
              • Jan 2023
              TVPartsToday.com. I will call tomorrow to ask for a replacement. Just thought it was strange that it has the exact same problem as before, and was wondering if it could be something else.
              • NZuercher
                • Jan 2023
                I may order a new TCon and LED board as well, since they're both relatively inexpensive.
                • NZuercher
                  • Jan 2023
                  So, I replaced the main board (again) and the TCon board. I finally got power to the RCon and the backlight turned on. But, now I just have a black screen with a series of vertical white stripes. What does that mean?
                  • nomoresonys
                    • 12097
                    • U.S.
                    #29
                    maybe try a firmware update, see if you can get everything paired up.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4289
                      • Italy - Milan
                      #30
                      replace back original tcon and cross fingers with kisses to pope's photo...
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Try re-seating all cables to the tcon and putting the old tcon back as Davi. P suggested
                          03-31-2024, 02:12 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          07-01-2024, 06:34 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
                        • shovenose
                          Christmas Light Power Supply Question
                          by shovenose
                          I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                          Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                          12-08-2023, 09:59 AM
