Sony kdl-46hx853 no power
  • imran333
    • Apr 2012
    • 48
    Hi I got Sony 46hx853, no power or standby light , service manual says to check standby voltage on pin no 10 I think on main board, and if voltage is there, then replace main board , standby voltage is present , I have another main board from different tv, but the main board is near enough identical except the audio connectors , I plugged it in and I get standby by light on tv, so the service manual seems correct, but I don't want to replace the main board as it's expensive, the near enough identical main board I got has a damaged connector and all the ic chips etc are identical, so I can use that board to salvage the parts from, the problem I have is no schematic so I'm kind of confused what to check j next , as there's no obvious problems on the main board, like no burnt components , checked some smd caps but no short circuit on them, nothing getting hot, so just need some help and advice, I can solder smd parts and got all the equipment, just need to figure out the problem,
    Hope someone can help ?
    • 12181
    • U.S.
    Re: Sony kdl-46hx853 no power
    Try test #3 below, try to do it just as instructed, post results here.
      • 12181
      • U.S.
      To be clear, the mainboard is the board where you plug your hdmi, cable tv etc. cables into, the powerboard is the one without those type connections.
        Show us good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
        • imran333
          • Apr 2012
          • 48
          Here’s picture of main board , I’ve checked voltages in power supply and they are all present, I got similar board I can salvage parts from, just need help to figure out what part has failed on main board as I don’t have schematic
          None of the 4 smd fuses on the main board are blown
            • 12181
            • U.S.
            Can't follow directions when offered help, I'm out.
            • imran333
              • Apr 2012
              • 48
              I tried the test and all voltages are present and I got another power supply and it made no difference , I’m sorry but I don’t understand what you wanted me to do ?
              Yes I never took pictures of the whole back if tv as I don’t have access to it yet but I will do
              I’m sorry I’m not ignoring your advice but I got hold of a power supply and it made no difference and all voltages are present once you plug it in and I checked voltages when pressing power button and voltages are all present and exactly same as the voltages written on the board, Ive narrowed it down to the main board and only a hour ago I tested with another power supply but exact same problem
              • imran333
                • Apr 2012
                • 48
                Hope you can still help as everyone makes mistakes
                  • 12181
                  • U.S.
                  Some mainboard and powerboard testing there: https://www.youtube.com/watch?v=ocqnqmBxiqY
                    • 12181
                    • U.S.
                    Mainboards can look similar but be very different, need to mach the alphanumeric string on the white stickers.
                    • imran333
                      • Apr 2012
                      • 48
                      I understand the main board I showed you is the main board from my tv but the main board I got which is similar I just want it to salvage the parts from as all the smd components are the same with the same smd part numbers , only difference is the audio connector, I'll check that video you sent and report back
                        • 12181
                        • U.S.
                        need close up picture of the map/legend describing the pins of connector on powerboard or just write them out with pin description like ground etc. and pin number for each pin.
                          • 12181
                          • U.S.
                          Another little test, unplug the wifi module if equipped and see if anything changes.
                          • imran333
                            • Apr 2012
                            • 48
                            I'll do that next but I'm presuming the power board is fine as I tried another known good working one which I borrowed from a friend but he doesn't have another main board for me to try , but everything is telling me it's the main board but I will take close up pictures of the connectors and voltages ,
                            There's no regulators on the main board like in the video you told me to watch but here's close up pictures of the main board , I was thinking maybe it's a fault with a dc converter as there's no standby light but I got no schematic
                              • 12181
                              • U.S.
                              It's a process of elimination, the backlights and powerboard can be tested if they pass the test you move on to the rest. It's how most of us test tvs, can't help without the requested pictures or info.
                              • imran333
                                • Apr 2012
                                • 48
                                When I plugged in the other main board I got , the standby light comes on so I'm presuming it's the main board that's faulty as with the original main board no standby light, I got backlight tester and I just need to figure out what the voltages should be in the first place, I got the pictures but if the main board was not faulty then I would have got blink code as it's a Sony and service manual says if there's standby voltage on pin 10 on main board which there is, it says it's the main board that's faulty so everything is telling me it's the main board
                                • imran333
                                  • Apr 2012
                                  • 48
                                  I've ruled out the power supply board as I tried another one and all voltages are correct , the backlights I really don't think so bcuz all the voltages was even on every set of wires I tried
                                    • 12181
                                    • U.S.
                                    What is the voltage of the BL-ON pin with tv in standby, and when you turn tv on??
                                      • 12181
                                      • U.S.
                                      What exactly does the tv do, do you get backlights or a flash of backlights??
                                      • imran333
                                        • Apr 2012
                                        • 48
                                        Tomorrow I’ll check backlight on voltage as I forgot but the tv does nothing at all but all I hear is relay click on when plugged in then nothing at all, but when I unplug the cord then I’ll hear relay click off, in the past on another faulty Sony tv where the power supply was faulty , the relay would click on when plugged in and click off straight away, but on this one it will click on when plugged in then nothing until I unplug the cord.
                                        So I’m thinking when it’s plugged in, the power supply is on the whole time but maybe main board is faulty so the main board is not sending the signal to turn backlights on and not able to give standby light or blink code as the main board is faulty bcuz when the similar main board is plugged in I got standby light but I never press power button in case the similar board blows something else
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
