Sony KDL-50W800C BLInk 5 times
  • sasser
    • Dec 2012
    • 364
    • Malaysia
    Masta please help. I got problem with sony KDL-50W800C.
    BLINKING 5 times. Suspected tcon board . Bord tcon no is T550HVN08.2 CTRL BD. Anybody exp with this tcon. Maybe can advice . Flash fimware will solve? Coz n short on board
  • neilc6
    • Nov 2015
    • 1550
    Re: Sony KDL-50W800C BLInk 5 times
    If 5 blinks is the tcon, check for voltage on both sides of the fuse. I see it marked 32V/3A. Second test is to power up the tv with only one side connected at a time from the tcon and see if you get a picture one side.
      +1
      Also "T550HVN08.2 CTRL BD" is the P/N of the Blank PCB not PCB assembly, you need to match the P/N as printed on the bar code sticker.
      • sasser
        • Dec 2012
        • 364
        • Malaysia
        Hye masta. Before i say thanks to both of sifoo. What i do is. I read back bios eprom on tcon. I put on my programmer. Then i backup and i place back bios ic. After that i pwr on with only one tcon. And i got display half. I pwr off then place both tcon cable. Wow display come back. Thanks u all
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          hello same problem here.. i got hold of this sony bravia kdl-50w800c the problem is black display with patch white with 5 red blinks immediately i assume its a tcon problem, i bought a tcon but unfortunately when i connect the tcon and power up the unit.. it only displays the logo of sony with the android title then goes black again with 5 red blinks.. what seems to be the problem.. thanks in advance guys..
          Never stop LEARNING because life never stops TEACHING!
            What happen if you do not have ribbon cables between T-CON and the LCD panel connected, and if you have it connected one at a time?
            • Duranitron
              • Jul 2014
              • 544
              • Philippines
              tcon is not compatible with my unit.. i already return the new tcon and replaced it with original tcon serial number and it works .. thanks for the time..really appreciate it..
                Thanks for the follow-up on the repair, I'm glad you get the correct T-CON.
                  • 12206
                  • U.S.
                  So that's all you did, was put the original tcon back in and it worked?
                    I think he is saying that he got another new TC-ON board that match the barcode sticker numbers this time, that is what I understand.
                      • 12206
                      • U.S.
                      Ok that makes more sense.
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        yah i bought a new tcon similar to the serial number of my original tcon. its an eye opener for me not to lean only to the board number but to the serial number.. the two have the same board number but different serial number ...
                          the number on the bar code is the PCBA (Printed Circuit Board Assembly) part number.
                          The T550XXXXXXX printed on the PCB is the Blank PCB that can be stuffed with many difference parts to make many required PCBA.
                          • Dobsuk
                            • May 2020
                            • 127
                            • England
                            Ohh guys. I just posted this problem related to the same issue may be. I was looking for these 5 blinks on Google but it did not show me any results from this forum. How stupid i am So is that mean that i need to buy another one T-Con with barcode the same like mine one and not only the model?
                              • 12206
                              • U.S.
                              Indeed, you need to match up those numbers on the sticker, just going by model number is a no no.
                              • Dobsuk
                                • May 2020
                                • 127
                                • England
                                Thank you. I will have a look for another one T-Con with the same sticker's number and fingers crossed
                                • WhiteWolfHellas
                                  • Jun 2019
                                  • 95
                                  • Greece
                                  Any chance anyone has repaired this T-Con for future reference? What chip goes bad similar to ISL9860?
                                  • chirath22
                                    • Mar 2022
                                    • sri lanka
                                    I do have same problem . can you please let me know how you backup e prom please?
                                    • Aakashlimbu
                                      • Apr 2022
                                      • 5
                                      • Nepal
                                      In sony tv the lvds cable mostly damaged.check if it is damaged or not.if it is ok then check tcon voltages.if all ok then open left side cable and watch.if same open only right side lvds and watch.if same problem you need to replace tcon.
                                      • thelankanguy
                                        Sony KD-55X9000F TCON Issue
                                        by thelankanguy
                                        The TV shows a black screen with no image.
                                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                        Later both ribbons were disconnected and TCON voltages were tested.
                                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                        There is also a short to ground in this circled inductor.
                                        Is this a TCON issue or something else ?...
                                        12-13-2024, 12:27 AM
                                      • bbrain
                                        Sony KD-55AG9 TCON?
                                        by bbrain
                                        I have this problem with my Sony 55' AG9.
                                        It flashes 4x.
                                        I have found the service manual, and seems it is the TCON.
                                        Before I buy a TCON can someone check the vid?
                                        Thanks in advance!...
                                        09-19-2024, 10:50 AM
                                      • EazyBone
                                        Sony 85x90CK 4 red blink
                                        by EazyBone
                                        So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                        But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                        Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                        Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                        07-18-2025, 12:53 PM
                                      • cheeky2
                                        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                        by cheeky2
                                        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                        01-08-2024, 05:56 AM
                                      • rimwall
                                        Sony KD-65x8500b - bad Tcon or panel?
                                        by rimwall
                                        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                                        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                                        b) the Tcon board is malfunctioning,...
                                        10-24-2023, 07:58 PM
