Polaroid TDA-03211C
  • Hondaman
    • Sep 2008
    • 1092
    Polaroid TDA-03211C
    Recently I grabbed a Polaroid TDA-03211C from someone's curbside trash. There was also a tube-style computer monitor, but I let the other trash-pickers take that.
    When plugged in, the LED light on the front of the TV changes from red to blue and the built-in DVD player spins for a short time before stopping (it is probably programmed into a ROM chip to search for a disc in the drive upon startup). The LED on the power board blinks at around 1 Hz.
    Here we have a picture of [part of] the power board. Clearly the 10 microfarad 450 working volts DC capacitors need replacing, they are bulging (between the "TC18813F / RoHS" and "PROVIEW" silkscreens). All capacitors are "HEC" brand.
    (Yes, this will take some time - I am busy with lots of work at my job, and around the house too.)
    Should I remove the heatsink and replace the others?
    • 12330
    • U.S.
    Re: Polaroid TDA-03211C
    Probably a good idea to replace them all, if it was for my own use I would just replace the bulgers and see if that solves it. It's not a huge tv so if you had to take the back off again it wouldn't be a big deal, your call.
    • crazycavan
      polaroid TQLHD24PR004 no power
      by crazycavan
      hi, my tv no longer starts like dead, no standby led
      motherboard : MS36639-ZC01-01
      panel : V236BJ1-P01
      flash spi: GD25Q64
      need usb firmware or to reprogram​
      05-05-2024, 08:40 AM
    • Chrissygizmo
      Polaroid p49fn0038k backlights flashing split second
      by Chrissygizmo
      Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
      When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
      Any help would be greatly appreciated
      Thanks in advance
      11-10-2022, 10:30 AM
    • snimmits
      Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
      by snimmits
      Good afternoon,
      I have a Polaroid P43D300.
      It shipped with WiFi and Bluetooth.
      Two weeks ago, I ran through the first time installation.
      This did a full reset and went through the first time setup.
      Once complete, I went to settings > sound.
      selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
      search completes and doesn't find any devices.
      I have tried everything I can think of.
      Can someone provide...
      03-01-2024, 09:26 AM
    • maamar-tdj
      Polaroid TV TQL48R4PR003 switch off after logo display
      by maamar-tdj
      I am looking for the Dump Firmware of this model.
      Mark: Polaroid
      Model: TQL48R4PR003
      Main board chassis: CV9203H-A42
      LCD Screen / Panel: 15y_s48ff11mb7s4lv0.1
      More information: W25Q32
      thank you for your reply
      05-26-2022, 08:53 AM
    • coax81
      Polaroid tql39r4pr002 TV switch off after logo display
      by coax81
      i have an issue with my polaroid TV Model : tql39r4pr002
      the standby led is red , and when i turn on the TV it shows the polaroid logo and turns off, also the standby led switches to blue the back to red .
      capacitors are apparently ok, i have 320V in the smoothing primary capacitor, and 13V in the diodes in the secondary.
      i don't understand why the mainboard switches to this mode and don't turn on.
      don't find any service manual for this model ,or the main board schematic. cv9203h-a42
      thank you for your help....
      08-12-2020, 08:43 PM
