LG 55EC930T - System Menu doesnt initialized
  • Tokenizer
    • Nov 2019
    • Singapore
    I have this LG 55EC930T that was fixed by me but I am still having some issues with it.
    At the moment this is what happens. TV can be powered on and watching Live TV without any issues. I am unable to use the home button on the Magic Remote. To enable the smart TV functions I used the ZAZA app with an IR blaster. pressing Menu will bring up, "initiaizing" then " System Manager, initialized", I can then use the magic remote.
    After turning off the TV, I will need to use the ZAZA app again before i can use the magic remote.
    I have attempted to reset to initial setup, but the tv wont complete the process. it will show me the spinning circles for 3 seconds before clicking off. Eventually it wont be able to turn on, to bring it back to the state that it can be turned on, I have to use RCoid App with IN_power to eventually get to the power only mode and exit that to the usual mode. I have also attempted to use in_stop with the same effect with the reset to initial setup.
    I am suspecting something is wrong with the software as the tv works completely fine. Current version 05.05.70
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8204
    Re: LG 55EC930T - System Menu doesnt initialized
    Sounds like you are on the right path. Try doing a firmware upgrade, factory default, etc.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4359
      • Italy - Milan
      I don't understand well the steps you made but try to shot In-start pulse so you can get access to service menu then you make a service reset. You also must to explain what you have fixed and how. We don't like misteries.. :-]
      • Tokenizer
        • Nov 2019
        • Singapore
        Let me go back to my original problem.
        I had two sets.
        Set 1, broken panel. Removed psu board, tcon board and mother board.
        Set 2, received in power only mode. Using zaza remote, managed to exit and power off to boot normally.
        My mistake then was to use set 2 to test the motherboard and tcon board from set 1. I tested first with the motherboard from set 1, everything works.
        My problems started when I changed tcon board with set 1. Though everything works. It started to behave strangely like powering off itself. I changed back to the original tcon board and got to this state.
        Sometimes using the original boards it also shutdown unexpectedly. I do think maybe there is a problem with the power supply board but it too coincidental to have started only after I changed the tcon board.
        I am able to get the instart but don't see an option for service reset.
        When I used in stop, the next time I turn on the TV, I see the webos logo before the tv clicks off. Subsequently I see it one more time, and the next I see the spinning circles before I am not able to turn it back on. To recover I have to user power only a few times before I am able to bring the tv back up.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4359
          • Italy - Milan
          well, i'm not familiar with LG service menu and i don' t remember which is the option to make a reset but the service manual will reveal it to you. What do you mean for "power only mode"? It's a strange situation because it seems that what you have called tcon has some differences, are you sure that all the boards have the same label/sticker code? Are you sure that connectors and cables from mainb. to "tcon" are now ok? There can be a conflict so for me a service reset can be a first option.
          • Tokenizer
            • Nov 2019
            • Singapore
            An update:
            After successfully resetting to initial via the system menu. The system manager now starts on it's own when I on the TV, hopefully there isn't anymore issues with the tv turning off by itself after this.
            • ds2010
              • Oct 2016
              • 21
              • Russian Federation
              Hi Tokenizer (or anyone who can help)
              I have a similar issue with "Loading..." and then "System Manager initialized"
              You mentioned in your last post in this thread that you solved the issue by "successfully resetting to initial via the system menu".
              I haven't found the factory reset option in either IN-START or in ADJ service menus.
              Can you pls guide me through and elaborate on what exactly you did to perform the factory reset via service menu? (that is, of course, if you still remember that yourself
              Thanks!
              • lotas
                • Jan 2016
                • 4639
                • Russia
                The reset is done with the command - "IN STOP", then the password "0413" is entered.
                • ds2010
                  • Oct 2016
                  • 21
                  Yeah, the topic starter mentioned that above a couple of times.
                  My concern is that after "IN STOP"+password, to turn the TV on, the P-ONLY has to be used (topic starter also mentioned that), and I am told that it would reset the usage hours (UTT).
                  Oh, by the way, will "IN STOP" also reset the panel calibration data? I remember reading somewhere about that, but I might be wrong here.
                  • lotas
                    • Jan 2016
                    • 4639
                    • Russia
                    https://webos-forums.ru/topic3173.html
                    • ds2010
                      • Oct 2016
                      • 21
                      Thanks! 107 pages of education!
                        LCD LED TV Service Menu Codes
                        TCL LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        10-31-2024, 03:58 AM
                      • Retro140
                        Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                        by Retro140
                        So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                        To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                        06-18-2023, 06:13 PM
                      • Ierwin
                        Philips 58PUS7805 Menu working but no/weird picture from video sources
                        by Ierwin
                        I got a 58pus7805 that shows some weird behavior.
                        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                        I managed to install the latest official firmware by holding the control button while plugging...
                        03-10-2024, 12:50 PM
                      • vf fa
                        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                        by vf fa
                        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                        01-31-2024, 01:40 PM
                      • tusiime
                        How to access Vizio m652i-b2 service menu
                        by tusiime
                        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                        09-15-2023, 09:57 AM
