Samsung le37c530
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Samsung le37c530
    Hello, I have this LCD TV on my workbench and after 5 minutes or so of working fine, it turns off by itself and the standby light turns on indefinately and the TV cannot be turned on. I have to unplug it for a couple of minutes in order for the TV to turn on.
    I have disconnected the cable to the main board and the PSU turns the backlight on, only for 5 minutes though. So the problem is with the PSU and not the mainboard. I haven't had the time to check anything yet but I was hoping someone here knows about this fault.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung le37c530
    resolder all parts on the heatsinks and also the transformers etc even if the joints look good reflow/add fresh solder then try the tv again.
      • 12146
      • U.S.
      Also you can check the transformers on the inverter board, the ones you have are easier to check than some
      tvs, youtube is your friend for examples of testing them.
        You need to show us the pictures of all the boards and the whole backside of the TV showing all the boards..
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4318
          • Italy - Milan
          i agree with reflow job on psu, do it on at least every big component's soldering unless you are experienced enough to detect "circled" solderings, thus those with ring crack. Check also the psu-mainb. cable's connector, it can be burned or something bad.
          • WhiteWolfHellas
            • Jun 2019
            • 95
            • Greece
            I have resoldered the PSU but the problem is still there. What else can cause this fault?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4318
              • Italy - Milan
              i have said it.... 8v[
              • vinceroger69
                • Mar 2012
                • 6714
                have you got a fan you can blow cold air at the psu and see if its a heat related issue
                • jetadm123
                  • 2169
                  Since you have 5 minutes before shutdown, you can try heating up each board with a hairdryer to see if you can accelerate the shutdown process. This will hopefully help narrow down which board is causing the problem.
                  • R_J
                    • 9535
                    I would start by replacing CS810 & CS809 capacitors, I would also replace CP807 & CM807, these are all on the ic's VCC line
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4318
                      • Italy - Milan
                      REPEAT: Check also the psu-mainb. cable's connector, it can be burned or something bad
                      • R_J
                        • 9535
                        From Post #1
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4318
                          • Italy - Milan
                          OK, so must check PSU>INVERTER cable..
                          • WhiteWolfHellas
                            • Jun 2019
                            • 95
                            • Greece
                            I heated the PSU and the problem came up faster, then I freeze sprayed the PSU and the TV turned on again instantly.
                            I resoldered every single component and the TV works all day now.
                            • WhiteWolfHellas
                              • Jun 2019
                              • 95
                              • Greece
                              The TV came back with the same fault after 4 days of normal operation. Maybe the capacitors need replament. I will start with this.
                                09-07-2024, 05:50 AM
                              • Egidio85
                                Samsung UE55F8000SZ Turns on and off immediately
                                by Egidio85
                                good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                This defect happens continuously, hearing the classic click of the relay every time.
                                Power supply board BN44-00636B
                                disconnecting the mains and lamps from the power board always causes the same problem.
                                Is it normal that without anything connected this power supply turns on and off cyclically?
                                any suggestions on what to check?
                                thanks in advance
                                03-11-2025, 12:45 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
