Samsung LED UN46H5203 No Backlights
  • sfernandes
    • Oct 2013
    • 229
    Hey guys,
    I need some help trying to troubleshoot this set.
    I have tested the LED Backlights with the Shopjimmy LED backlight tester and I could see through the back of the panel the LEDs lighting up.
    Flashing a flashlight into the panel I could see the image.
    I have taken voltage measurements here they are...
    TV in running mode
    CNM803 CONNECTOR ON PSU
    Pin 1 - 13v
    Pin 2 - 13v
    Pin 3 - 13v
    Pin 4 - 13v
    Pin 5 - 0v
    Pin 6 - 3.297v
    Pin 7 - 1.578v
    Pin 8 - 3.328v
    5303 CONNECTOR ON PSU
    Pin 1 - 310v
    Pin 2 - 308v
    Pin 3 - 260v
    Pin 4 - 262v
    Pin 5 - 0v
    Pin 6 - 235v
    Pin 7 - 233v
    Pin 8 - 0v
    Pin 9 - 0v
    TV IN STANDBY
    CMN803 CONNECTOR ON PSU
    Pin 1 - 11.95v
    Pin 2 - 11.95v
    Pin 3 - 11.95v
    Pin 4 - 11.95v
    Pin 5 - 0v
    Pin 6 - 0v
    Pin 7 - 0v
    Pin 8 - 0v
    Pin 9 - 0v
    Pin 1 - 208v
    Pin 2 - 208v
    Pin 3 - 159v
    Pin 4 - 159v
    Pin 5 - 0v
    Pin 6 - 134v
    Pin 7 - 134v
    Pin 8 - 0v
    Pin 9 - 0v
    I have attached pictures showing the PSU and the Main and also close-ups of the pin legends. I also have the service manual for this set, but it's not really informative. Another thing I find odd that I should mention is that the standby voltage on this set is supposed to be 8v according to what's printed on the PSU meanwhile on standby it's running 11.95v, not sure if that's an issue, but it's worth noting.
    Re: Samsung LED UN46H5203 No Backlights
    The connector has pin label for each pin so you should put the name of each pin on the connectors that you report so we can easily see what each pin is for.
    Also recheck the way you count the pin and the pin name as listed in the chart, I.E, the CNM803 connector has odd and even column pins, the odd pins can be access from the top side of the board the even number pins has to access from the wire entrance side of the connector.
    Your report for
    Pin 1 - 13v
    Pin 2 - 13v
    Pin 3 - 13v
    Pin 4 - 13v
    Pin 5 - 0v
    Pin 6 - 3.297v
    Pin 7 - 1.578v
    Pin 8 - 3.328v
    Look at your pin number and the report, you will see that they do not match the chart (the connector has 10 pins), as you can see fro example the pin 8 is GND so how can you have 3.328V, that is why you need to put down the name then you can easily see the errors you made.
    Please redo you measurement again.
    • sfernandes
      • Oct 2013
      • 229
      Your report for
      Pin 1 - 13v
      Pin 2 - 13v
      Pin 3 - 13v
      Pin 4 - 13v
      Pin 5 - 0v
      Pin 6 - 3.297v
      Pin 7 - 1.578v
      Pin 8 - 3.328v
      My bad, I'm sorry for my mistake here are new measurements.
      ON STATE
      CNM803 on PSU from Main
      Pin 1 A13v - 12.94v
      Pin 2 OD_UD - 3.297v
      Pin 3 A13v - 12.94v
      Pin 4 BLU_PWM - 1.574v
      Pin 5 A13v - 12.94v
      Pin 6 PWR_On/Off - 3.328v
      Pin 7 A13v - 12.94v
      Pin 8 GND - 0v
      Pin 9 GND - 0v
      Pin 10 GND - 0v
      STANDBY STATE
      Pin 1 A13v - 11.90v
      Pin 2 OD_UD - 0v
      Pin 3 A13v - 11.91v
      Pin 4 BLU_PWM - 0v
      Pin 5 A13v - 11.93v
      Pin 6 PWR_On/Off - 0.126v
      Pin 7 A13v - 11.94v
      Pin 8 GND - 0v
      Pin 9 GND - 0v
      Pin 10 GND - 0v
      • sfernandes
        • Oct 2013
        • 229
        CNL802 CONNECTOR ON PSU TO LED's
        ON STATE
        Pin 1 D1+ - 310v
        Pin 2 D1+ - 308v
        Pin 3 S1- - 260v
        Pin 4 S2+ - 262v
        Pin 5 NC - 0v
        Pin 6 S2- - 235v
        Pin 7 S3+ - 233v
        Pin 8 D1- - 0v
        Pin 9 D1- - 0v
        STANDBY STATE
        Pin 1 D1+ - 208v
        Pin 2 D1+ - 208v
        Pin 3 S1- - 159v
        Pin 4 S2+ - 159v
        Pin 5 NC - 0v
        Pin 6 S2- - 134v
        Pin 7 S3+ - 134v
        Pin 8 D1- - 0v
        Pin 9 D1- - 0v
        • sfernandes
          • Oct 2013
          • 229
          CNL802 CONNECTOR ON PSU TO LED's TESTED WITH CABLE DISCONNECTED WITH POWER ON
          Pin 1 D1+ - 305.2v
          Pin 2 D1+ - 305.0v
          Pin 3 S1- - 0v
          Pin 4 S2+ - 0v
          Pin 5 NC - 0v
          Pin 6 S2- - 0v
          Pin 7 S3+ - 0v
          Pin 8 D1- - 0v
          Pin 9 D1- - 0v
          CNL802 CONNECTOR ON PSU TO LED's TESTED WITH CABLE DISCONNECTED WITH TV ON STANDBY
          Pin 1 D1+ - 207.5v
          Pin 2 D1+ - 207.7
          Pin 3 S1- - 0v
          Pin 4 S2+ - 0v
          Pin 5 NC - 0v
          Pin 6 S2- - 0v
          Pin 7 S3+ - 0v
          Pin 8 D1- - 0v
          Pin 9 D1- - 0v
          Tried running the TV without the cable that connects the main to the PSU to see if I get backlights, but I didn't get anything (Not sure if this unit has pull up resistors in the power supply)
          Shopjimmy sells a new IC1304 for this set
          https://www.shopjimmy.com/samsung-bn...eprom-only.htm
          Not sure if that would fix my problem.
            • 12083
            • U.S.
            Seems like "Pin 4 BLU_PWM - 1.574v" is too low, thinking that's the backlight on signal coming from the mainboard.
              • 12083
              • U.S.
              Could try unplug the wifi module and see if tv starts up.
              • neilc6
                • Nov 2015
                • 1550
                You most likely have bad backlights. You can report the voltages read by the led tester probing from the back connector or open up the panel to observe each strip powered from the tester. EH and H series, the LEDs will burn out until there are only a few working or there is an open in the string or there is damage to the PS..
                • R_J
                  • 9515
                  I agree, backlight led problems, likely one or two are shorted causing abnormal current and shutting down the led circuit.
                  • sfernandes
                    • Oct 2013
                    • 229
                    Tried that and same thing.
                    • sfernandes
                      • Oct 2013
                      • 229
                      The voltages on the LED tester say...
                      Pin 1 & 2 - 55.1v
                      Pin 4 - 29.9v
                      Pin 7 - 0v
                      Pin 8 & 9 - 85.8v
                      What do you figure from those numbers?
                      • sfernandes
                        • Oct 2013
                        • 229
                        I'm getting mixed opinions, I would prefer not to have to risk taking out the panel if I don't have to.
                        Could anyone be more sure what's happening?
                        budm any ideas I haven't heard your opinion yet?
                        • R_J
                          • 9515
                          Pin 1 & 2 - 55.1v
                          Pin 4 - 29.9v
                          Pin 7 - 0v
                          Pin 8 & 9 - 85.8v
                          The pin numbers are wrong, Pins 1&2 are the same connection, pin 5 is not used, pins 8&9 are connected together.
                          Disconnect the plug and check the 3 strings:
                          Between pins 2&3, 4&6, 7&8
                          • sfernandes
                            • Oct 2013
                            • 229
                            Ok here are the correct pin readouts...
                            Pins 2 & 3 - 55.1v ( Panel lights up)
                            Pins 4 & 6 - 29.9v (Panel lights up)
                            Pins 7 & 8 - 313v (panel doesn't light up)
                            What does this mean?
                              You have open circuit on the LED string connected to pin 7 (Anode of #3 LED string) and 8 (Cathode of the #3 LED string which is the Cathide return of the series connected LED strings).
                              • R_J
                                • 9515
                                It looks like the string between 7&8 is open.
                                • sfernandes
                                  • Oct 2013
                                  • 229
                                  Great so I guess opening the panel it is sigh lol. I have many LEDs from tvs laying around could I not just replace the burnt out ones, if so are all LEDs the same?
                                    They are not all the same, you have to match the footprint and polarity, Voltage and current rating, etc.
                                    It is better to replace the whole set of the LED strips.
                                    • sfernandes
                                      • Oct 2013
                                      • 229
                                      This set belongs to a friend that says he doesn't want to spend money on it really and asked me if there is a way to jumper the LED to the next led, then turn down the backlight so he could get a bit more out of it. Is that possible?
                                        You may be able to bypass one to two 3V LEDs, I would not do more than that. The problem is that some LEDs already went bad so you can expect more to go bad later also.
                                          MSI Stealth 17 STUDIO A13V-022 Notebook Specification for Upgrade or Repair
                                          This specification for the MSI Stealth 17 STUDIO A13V-022 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17 STUDIO A13V-022 boardview and 17 STUDIO A13V-022 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 06:31 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • soler88
                                          Samsung UN46H5203 backlight issue - stumped
                                          by soler88
                                          I am trying to fix this tv that has image and sound but no backlight. Replaced all led strips and each strip turns on using a led tester but do not get any backlight when the tv turns on.
                                          I disconnected the main board from the PS but still no backlight.
                                          Looking at previous threads, nothing is jumping out at me and I'm stumped.
                                          Here are the voltage measurements:
                                          ON STATE
                                          Pin 1 A13v - 13.09v
                                          Pin 2 OD_UD - 3.3v
                                          Pin 3 A13v - 13.09v
                                          Pin 4 BLU_PWM - 1.6v
                                          Pin 5 A13v...
                                          10-09-2024, 07:28 AM
                                          MSI Creator Z17HXStudio A13V Notebook Z17 HX Studio Specification for Upgrade or Repair
                                          This specification for the MSI Creator Z17HXStudio A13V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z17HXStudio A13V boardview and Z17HXStudio A13V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 06:38 AM
                                        • bstewara
                                          Samsung un49mu7000f dead no power
                                          by bstewara
                                          Hi.
                                          I'm working on a Samsung UN49MU7000F that has no standby LED indicator.
                                          No POWER
                                          The power supply board is part number BN44-00876A
                                          The main board number is BN94-12399A
                                          I am stuck.
                                          I have replaced both pwr supply and main board with no changes.
                                          Here are some of the readings from my multi meter on various locations on my power supply
                                          MAIN BOARD UNPLUGGED. BACK LIGHTS ON PLUG CNL802 85 volts
                                          Backlights are all illuminated and in operating range.
                                          MB PLUG CNM803. - UNPLUGGED
                                          PIN 1 FAN COUNT - Open...
                                          10-08-2021, 06:42 AM
