Ue49m5500 no picture but backlights
  • sordids999
    • May 2013
    • 2158
    Hi guys
    Got this samsung today but no picture
    on the screen but backlights are good
    Tcon fuse has 12v
    Pin 1 Nc 3.26v
    Pin3 13v 12.7v
    Pin5 13v 12.7v
    Pin7 13v 12.7v
    Pin9 13v 12.7v
    Pin 11 and
    Pin 2 of on/off 3.3v
    Pin4 od/us 3.26v
    Pin7 blu_pwm 3.26v
    Pin8 ps_on 3.26v
    Pin 10 gnd
    Pin 12 gnd
  • sordids999
    • May 2013
    • 2158
    Re: Ue49m5500 no picture but backlights
    If I disconnect the left side tcon ribbon I have a white screen
    If I disconnect the right side ribbon I have a blue screen
    • CapLeaker
      Leaking Member
      • 8325
      You shouldn’t see a blue screen. You can check the LVDS pairs with an oscilloscope, while flicking the menu on and off with the remote. Kinda crude way of testing if the main board works. Other than that, jam a new tcon in, they are usually cheap enough.
      • sordids999
        • May 2013
        • 2158
        I spoke to the guy his wife used window lean spray to clean the screen then the tv just went off but still with sound and a glow on the screen
        Would this damage the tcon ?
        I'm thinking more cof strips but cant see any damage
        • sordids999
          • May 2013
          • 2158
          Both lvds ribbons connected no voltages on the following pins in the picture
          With the left ribbon disconnected voltages are good of the tcon
          • diif
            • Feb 2014
            • 6978
            • England
            If you can't see any liquid damage where the film meets the screen then you might get lucky and find it's a shorted capacitor.
            • DXseekerMO
              TCL 55US57 backlights, no picture.
              by DXseekerMO
              So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
              The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
              Power Supply, main and T-CON board are working.
              Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
              Unhook FFC from left side...
              09-18-2021, 03:56 PM
            • sordids999
              SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
              by sordids999
              Hi
              Really stuck on this TV
              I'm thinking it's a bad screen ?
              Voltages all seems good
              Tcon 12v ok
              Remove one tcon cable at a time no half image on the screen just backlight and no picture
              even tried the tape trick still no luck
              Thanks...
              05-12-2025, 10:36 AM
            • stinger
              Samsung UN70TU6980FXZA no sound no picture but does have backlights
              by stinger
              When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
              04-17-2024, 03:06 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
