I used this site a couple years ago and got great help, fixed 3 tvs. One of which I am having problems with again, first time it was a bad mother board. The tv stays outside under a covered porch with a cover on it when not in use. The tv started powering itself off after 2 or 3 seconds following initial start up. At first I could unplug it and after plugging it back in it would come on and stay on. Now it turn itself off no matter what. I can disconnect the tcon and after unplugging and plugging it back in all the backlights will stay on. However, if I just power on and off it will not come back on the led power light will just flash a couple times. In this state the pins on the psb show no readings. Then if I unplug AC and plug back in all the readings go to normal. At first I thought it was the tcon since lights stayed on after disconnecting, but now I realize the psb loses power on the secondary side if I just turn it off and on using the remote or the power button, thanks in advance and hope to get this back running in time for my super bowl party.
Another LG, 55ln5100 power issues
Tags: None
Re: Another LG, 55ln5100 power issues
LG LN series have high rates of backlight failure. Is the tv turning off completely or is the tv on but with the backlights shutdown? Without a led tester, you can monitor the voltage going to the strips to see if they peak up and settle.Last edited by neilc6; 01-20-2020, 04:43 PM. -
I can see if I can figure out how to test the leds. I was thinking something else since the psb connector shows no readings after powering the TV off then back on using the power button but then it has correct readings if I unplug ac and plug it back inComment
1) We need good clear pictures of the whole backside of the TV showing all the boards.
2) You need to report all the Voltage readings of the power supply connectors that go to the main board when TV is OFF and when the power switch is activated, you MUST put down the pin name and the Voltage reading for EACH pin so we can easily spot the bad Voltage readings.Never stop learning
With TV plugged in and without turning on TV the only 2 readings are 3.5v on pdmi2 and pdmi1, no other outputs on the connector. If I power off with button and back on all the readings stay the same. However if I unplug ac and plug it back in all the back lights come on and both 12v pins read 12v, the 24v pin reads 24.3 and both pdmi2 and 1 read 3.5. If I power off using the button it goes back to original state of no voltage readings other than the 2 pdmi pinsComment
Wonder if it's an eeprom issue, maybe try heating with a hairdryer and or cooling with freezespray or inverted can of duster IC1300, give it about 15 seconds, plug tv in, see if it starts or anything changes.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
You will get the switched 12V/24V when PWR-ON control signal from main board is present.
You will get backlights when PWR-ON, DRV-ON, and PDIMs from main board are present.
So it looks like the main board not always sending out all the control signals.Never stop learning
I can get all normal readings when I unplug the TV and plug it back in but after that start up if I power off with the button I lose power other than the pdmi pinsComment
How about the PWR-ON (PS-ON) and DRV-ON (BL-ON)?
So it looks like the main board not always sending out all the control signals.Comment
"Press the power button and no backlights come on but I have 3.3 on the DRV-on pin. and still 3.5 on both pdmi pins." So what is the PWR-ON (PS-ON) in that condition? I do not see any report on the PWR-OM pin, no PWR-ON = no 12V/24V.Never stop learning
I was testing the back of the plug assuming they were ps-on and dvr were connected. I'll attach a picture. Weird thing just happened, standby light was on, I pushed power button and no voltage readings other than pdmi, standby light went off and now standby light won't come back on and unplugging ac doesn't help, backlights will not come back on nor will the standby light. I still get 3.5 on pdmi but no other readingsComment
So main board is not sending ALL the needed control signals for the TV to work at this point.
Control signal: <1V = OFF, >2 ~ 3V = ON.Last edited by budm; 01-21-2020, 09:57 PM.Never stop learning
OK I ordered eeprom ic1300 gonna try replacing that. It was just strange that all the sudden I lost standby light. Thanks for all the helpComment
Not your tv model number but maybe worth a watch
https://www.youtube.com/watch?v=kbjNq1AyF00&t=362sComment
Currently I can not get standby light back on. After removing the connector from psb and testing top and bottom pins I have no voltage on pdmi, pwr or drv. Nor 120v or 24v, only 2 readings are the 2 3.5v pinsComment
Check D201 and the rest of the diodes, check for bad/cold solder joints on bottom side of board, look closely at the solder joints of components on heatsinks and on transformers, sometimes they look good but are bad or loose.Last edited by nomoresonys; 01-22-2020, 08:28 AM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
I inspected everything under the psb and all looked good. What are the 2 3.5volt pins for? meaning are they responsible for sending power to the mainboard and it triggers all the other voltages?Comment
Did you check all the diodes on powerboard? just check m in diode mode, should get a reading in one direction usually .2~.7 or so then reverse the test leads and should read OL, simple diode testing there: https://www.youtube.com/watch?v=mMXDa5hVzXAQuit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by EazyBoneI got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
