Sharp Aquos LC-70LE650U weird screen, please help!
  • Slavabusy
    • Jan 2020
    • 31
    • Usa
    Got this from some office, it was on the wall in conference until started acting strange. I took it off the wall and transported home in my minivan. Plugged in the power cord, and What?! It was working fine, except for a few small white spots on the screen. Didn't use it for a week or so.
    Now, a week later, it acting weird again.
    It is responding to remote, but so slow, that previous content is overlapping next screen in transition. After I press some button, it takes couple of minutes until it will get there, slowly.
    Btw, I was able to do a factory reset with volume down and input buttons.
    Didn't help any.
    Here is some pictures I took with 2 minutes intervals.
    Please help me fix it, please!
  • Slavabusy
    • Jan 2020
    • 31
    • Usa
    Re: Sharp Aquos LC-70LE650U weird screen, please help!
    This is what I see inside, visually looks good, no bad caps.
      • 12331
      • U.S.
      Maybe take it down to where you can get at the side tabs, usually you will notice some damage, like black looking burnt cof (chip on film) or one will be hotter than the rest or bad connection or sum such.
      • Slavabusy
        • Jan 2020
        • 31
        • Usa
        Thanks. What is best way to take off the frame without damaging lcd?
        It is 70”, kinda big
          • 12331
          • U.S.
          Seems like you are having same problem as Norcal in this one, you could try his test there to try to confirm, there is still the save by Freakafter8 that you can try once you verify bad tab/s on one side: https://www.youtube.com/watch?v=IZQRVqtIfns
            • 12331
            • U.S.
            https://www.youtube.com/watch?v=yjo8y8iQWLs
            • Slavabusy
              • Jan 2020
              • 31
              • Usa
              You guys are awesome!
              • Slavabusy
                • Jan 2020
                • 31
                • Usa
                With right cable disconnected (facing from the back) it looks this way:
                • Slavabusy
                  • Jan 2020
                  • 31
                  • Usa
                  With left one unplugged it looks better, but still there's horizontal lines in both situations.
                  What side tabs am I looking for?
                    • 12331
                    • U.S.
                    Second part there, notice how he unhooks the bottom connector to check it out: https://www.youtube.com/watch?v=OiXhb_jGJKE
                    • Slavabusy
                      • Jan 2020
                      • 31
                      • Usa
                      Thank to nomoresonys and badcaps.net!
                      I got that panel saved by removing all tabs on the right side (as facing screen)
                      Btw, disconnecting these tabs from the circuit plug didn't show any clear results for me.
                      Only after removing, peeling them off the screen it was fixed.
                      I also decided to prime those open spots with liquid electric tape to avoid moisture getting there in the future.
                      Thank you!!!
                        • 12331
                        • U.S.
                        Well done, nice save.
                        • scubacamper
                          Sharp Aquos LC-70C6400U Half Screen Dark
                          by scubacamper
                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                          05-03-2025, 12:19 PM
                        • sefoster
                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                          by sefoster
                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                          11-20-2022, 09:29 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • thesharpfella
                          Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                          by thesharpfella
                          Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                          07-23-2024, 10:37 AM
                        • EazyBone
                          Sharp LC-65Q620U White Screen
                          by EazyBone
                          Another TV topic!!
                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                          08-21-2024, 12:56 PM
