Re: Akai LCT2662 with bad caps
I found a very similar schematic for your set. I don't think it's 100%, but it appears to be close enough to get a good understanding. It's a large PDF file. ARRRRGH!!!
Did you clean up the mess on the board from the vented caps? That electrolyte is conductive and could be causing the problem.
It could be a problem on the back light inverter board. Do you get any illumination?
I don't see any 24v reading in your voltage readings? That's provided through connectors CN5 & CN8 that are side by side in the corner with big caps. They use 1/2 the connectors for (+) and the other for (-). The end towards the mounting hole is (-). Confirm the voltage.
One of those connectors supplies power to the inverter board. Disconnect the one that does and then power on the set and see if the noise goes away. It may not power on without it connected. I am not sure either way.
If it does power up and the noise goes away, then the likely suspect is the back light inverter board. They run about $60-70.
http://www.shopjimmy.com/back-light-...-lct2662-2.htm
If it does not, then pull the other connector and try again. If the noise remains, then I think the problem is still on the PSU. Try to localize the noise if you can. A paper towel tube to your ear may help.
If no 24v, check diode D10 & MOSFET Q2. They're on the 2 heat sinks adjacent to the big cap area. Also, check those power resistors for open. The (5) large gray ones mounted vertically and sleeved.
Toast
EDIT: Verify the new caps were installed correctly. Polarity-wise that is.
Toast
