Samsung UN60H6203AFXZA steady flashing backlights
  • hidperf
    • Jan 2015
    • 13
    After spending unknown hours searching the web, I keep ending up here so I'm hoping someone can help me with my problem.
    I did find this thread https://www.badcaps.net/forum/showthread.php?t=69298 but the OP didn't report back on his results.
    As the title says, I have a Samsung UN60H6203AFXZA and as soon as I plug it in, the LED backlights begin to steadily flash. The TV does not power up that I can tell. I get no boot-up sequence or sound.
    Power supply board is BN44-00775A. I don't see any bad caps or signs of excessive heat anywhere on the boards.
    If I unplug the main board from the power supply board, but leave the LEDs connected, I still get the steady blinking of the LED backlights.
    If I reconnect the main board and unplug the LED backlights from the power supply board the stand-by LED will blink a few times (I counted 6) but it doesn't seem to respond when I press it. I've tried shining a light through one of the holes but I can't see anything showing up on the screen.
    With power connected to the power supply, the main board and LEDs disconnected, and the negative probe of my multi-meter connected to the board grounding screw, the voltage readings are as follows.
    Power board output
    CNM803
    1 A13v = 12.93v
    3 A13v = 12.93v
    5 A13v = 12.93v
    7 A13v = 12.93v
    9 GND = 0
    2 UD = 2.35v
    4 PWM_BLU = 3.35v
    6 PS_ON = 4.55v
    8 GND = 0
    10 GND = 0
    LED connection - LED strips NOT connected
    CNL802
    D+ = 465v
    D+ = 465v
    Nc = .002v
    S- = .002v
    Nc = .001v
    S+ = .001v
    Nc = .001v
    D- = -.002v ??
    D- = -.002v ??
    LED connection - LED strips connected and flashing, which made it difficult to get accurate measurements.
    CNL802
    D+ = 103-112v
    D+ = 103-149v and rising
    Nc = -.006-.013v
    S- = ~35v
    Nc = -.003-.013v
    S+ = -.06-.08v
    D- = -.166- -.3v
    D- = -.3v
    I also tested the LED strips with an LED tester and got these results.
    Checking the LED plug connections A in the attached photo = 77v
    Checking the LED plug connections B in the attached photo = 48.3v
    I did read in this thread that LED voltage could possibly be 113v, but I'm not sure if that applies to the exact model.
    https://www.badcaps.net/forum/showth...ht=bn44-00775A
    So, from all that information, my hunch is bad LEDs. But the fact that the TV doesn't seem to power up with the LEDs disconnected is throwing me off.
    Thoughts?
    More info needed?
    Next steps?
    Thank you in advance!
    I've attached several pictures of the boards and connections.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung UN60H6203AFXZA steady flashing backlights
    You have some burnt out leds.
    • R_J
      • 9625
      I agree, bad led's or bad plug connection, your test of CNL802 S- and S+ should be the same as those two pins are connected together, so maybe check that your plug does'nt have issues.
      Pins 1&2 connected together
      pins 3,5&7 No Connection
      Pins 4&6 connected together
      • hidperf
        • Jan 2015
        • 13
        I was thinking LEDs myself, but this is a first for me so I thought I'd ask some experts.
        R_J, are you saying I should check voltage between 1&2 and between 4&6? With the LEDs unplugged I assume?
        • R_J
          • 9625
          No, that's not what I am saying, Look at the back of the board and you will see what I mean.
          D+ = 103-112v
          Nc = -.006-.013v
          S- = ~35v <--------- This connection
          Nc = -.003-.013v
          S+ = -.06-.08v <--------- And this connection are the connected together
          D- = -.166- -.3v
          D- = -.3v
          The voltages can not be different, If they indeed ARE different I suspect the plug is not making proper connection between S- and S+
          Also NC means NO CONNECTION. there will be 0 volts on those pins
          • hidperf
            • Jan 2015
            • 13
            D+ = 103-112v
            Nc = -.006-.013v
            Nc = -.003-.013v
            D- = -.166- -.3v
            D- = -.3v
            I gotcha now. I pulled the board and the traces look good.
            Tested S- and S+ again with the LEDs in place and they were the same, though jumping around a bit as the LEDs flashed.
            I figured the NC had nothing going to it. My meter was showing negative voltage so something must be going on there.
            Thanks for the help!
            I've got another older Samsung that I think has bad caps. That's my next project.
            • R_J
              • 9625
              The traces are likely ok, but If the wire from the panel that connects to pin4 was loose in the plug, or if the wire from pin 6 was loose and not making good contact, the entire led string would look open to the circuit.
              The voltage on pins 4&6 should be aprox. half the voltage of D+ which should be 326VDC but if the led string is open or has led current issues, the led drive controller ic will shut off the boosted voltage and the voltage will drop to around the 100vdc basic VD supply.
              • hidperf
                • Jan 2015
                • 13
                Well, the LED back lights were definitely bad. Replaced them and they tested right at 112v.
                But when I put it back together, I now have this.
                I was hoping I just didn't attach one of the ribbon cables for the T-Con board but I rechecked and they're all good.
                • hidperf
                  • Jan 2015
                  • 13
                  Anyone want to buy a Samsung UN60H6203AFXZA for parts? Brand new LEDs!
                  • ShatterMasters
                    • Oct 2017
                    • 14
                    I'd be interested in the PS board?
                    • MrC10-85
                      • Jun 2021
                      • U. S. Of America
                      What's the pet number on the led strips I will have to replace mine since I'm having the same issue and I already replaced the power board.
                      • hidperf
                        • Jan 2015
                        • 13
                        ShatterMasters, I didn't see your reply. I still have the board if you're interested. I pulled all the parts from the unit before I trashed it.
                        I don't have the part number, but I bought them from Shop Jimmy. If you put your model number in there, it'll show you what fits.
                          MSI Stealth 17 STUDIO A13V-022 Notebook Specification for Upgrade or Repair
                          This specification for the MSI Stealth 17 STUDIO A13V-022 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17 STUDIO A13V-022 boardview and 17 STUDIO A13V-022 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 06:31 AM
                        • rddube
                          LG 50lb6100 flashing backlights unsusual fix!
                          by rddube
                          Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
                          Read all the discussions on the web and on Badcaps (wonderful forum!!) and...
                          03-16-2022, 05:46 AM
                          MSI Creator Z17HXStudio A13V Notebook Z17 HX Studio Specification for Upgrade or Repair
                          This specification for the MSI Creator Z17HXStudio A13V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z17HXStudio A13V boardview and Z17HXStudio A13V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 06:38 AM
                        • Chrissygizmo
                          Polaroid p49fn0038k backlights flashing split second
                          by Chrissygizmo
                          Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
                          When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
                          Any help would be greatly appreciated
                          Thanks in advance
                          11-10-2022, 10:30 AM
                        • JunkmanJimbo
                          JVC lt-42em73 Flashing Backlights
                          by JunkmanJimbo
                          First I replaced the backlights. Then I found three bulging capacitors, one leaking, on the power supply board. Now, when I turn on the tv, the picture flashes with an image and then the picture goes away. I can unplug the tv and plug it back in, turn it on and the same thing happens. Please help. Thanks!
                          09-01-2022, 06:56 AM
