Samsung UN55J6201AFXZA Powers On+ Image but No Backlights
  • R_J
    • 9535
    Re: Samsung UN55J6201AFXZA Powers On+ Image but No Backlights
    You need to check the resistance of R9162 and R9161 (done with power supply disconnected from ac)
    It is hard to tell from the picture but I think R9162 is 27Ω, R9161 is 0.3Ω
    • DeatRaton
      Gio
      • Oct 2019
      • 36
      As far as the LED drive on the supply board. Is it normal to get readings on CNL802 of
      M1+ 217V
      M2+. 185V
      M3+. 154V
      M4+. 123V
      M5+. 92V
      I may be really wrong but aren't these usually the same Voltage across the board or is this fine?
      R9162- 2.2
      R9161- 0.8
        Are those readings with LED connector in place or not in place?
        Put the LED connector in placeDid you leave the black probe on the chassis and Red probe on M1+ then turn on the TV while watching the meter to see if the Voltage jumps up > 217?
        What do you get on M1- when you move the red probe to M1- and then turn on the TV?
        Based on your readings (if the LED connector is in place), it shows that M1 LED string has open circuit.
        The LED strings are connected in series to form one large LED string.
        M1+ the Anode of the first LED string that is fed by the LED power supply boost converter output, M1- is the Cathode of the LED #1 string, this cathode is then connected to the M2+ (Anode) of the #2 LED string, the M2- (Cathode) is connected to the M3+ (Anode) of the #3 LED string , and so on and on.
        Samsung BN44-00774A
        https://www.shopjimmy.com/samsung-bn...led-board.htm#
        • R_J
          • 9535
          If those voltages were normal you would have your backlights, The M1+ is the main led supply to the first string, It should be +268 volts.
          The difference between M1+ and M2+ is 32 volts, that line feeds one string of 14 led's so each led on the string is getting aprox, 2volts (I would guess they are lit but very dim) As you can see, each strinig is supplied by aproximately 30 volts, that is not enough voltage to light the led's, as each led needs around 3 volts
          The diodes (DM841,2,3,4C) off of TM801CS transformer supply the base +217 volts and is filtered by CM841.
          This voltage is feed through T9101C. It then needs to be BOOSTED by Q9101C to +268 volts. (similar to the pfc boost circuit) Q9101C is driven by IC9101, So it is possible IC9101 has a problem
          Post the number of IC9101 so we can check to see if it has VCC etc. It might be a SEM5027
          • DeatRaton
            Gio
            • Oct 2019
            • 36
            Samsung BN44-00774A
            M1- is getting a 185V
            Yes I have the black probe on the chasis and red on the pins.
            And yeah those readings are with the LED connector. When the connector is off I get 217V on M1+
            • DeatRaton
              Gio
              • Oct 2019
              • 36
              C9101 if hats what you meant had 217V
                But I thought they are .xxx V FOR 2 ~ 5.
                M1+ 217V
                M2+. 185V
                M3+. 154V
                M4+. 123V
                M5+. 92V
                So they are actually 185V, 154V, 123V, and 92V.
                The key point is that the probes must be in place before turning on the TV, if that is what you did then the boost converter is not working as RJ suggested.
                • R_J
                  • 9535
                  Have you had a look at the back of the board ? Q9101 is the FET that BOOSTS the raw 217 volts to 268 volts
                  I am gussing that CM888 is the Vcc supply filter cap. for the sop16 driver ic, check the voltage on J840 (ic9101 vcc) should be +13volts
                    I would check boost converter diode D9101 also.
                    • DeatRaton
                      Gio
                      • Oct 2019
                      • 36
                      D9101 gave me 217V reading
                      • DeatRaton
                        Gio
                        • Oct 2019
                        • 36
                        The voltage on J840 was 12.75volts
                        And the FET Q9101 gave me a reading of 217v
                        • R_J
                          • 9535
                          I know you only have 217v on Q9101. Thats because that BOOST circuit is NOT working.
                          Check that D9101 is not shorted using diode test.
                          The drive ic is getting vcc so it could be that the ic is bad, or more likely the ic is in protection.
                          Are you sure the voltage on M1+ NEVER reaches 268 volts. You need to have the meter ON that point when the tv is first pluged in and turned on. If there is any error in the led current or voltage, the ic will shut down the boosted voltage within 1/2 a second and all you will read is the 217v.
                          Also check if you have the backlight ON voltage at the ic itself
                          • DeatRaton
                            Gio
                            • Oct 2019
                            • 36
                            I included a picture of the diode reading I got.
                            And no M1+ goes up to 217 max, it creeps its way up to 217v its not an instant jump to 217 and never goes above that at any point. Not when its plugged in with negative on chasis and positive on M1+ pin before plugged in. When turned on as well only up to 217.
                            • R_J
                              • 9535
                              Ok so the diode is ok. so the problem seems to be with the led driver/boost circuit, (whatever the ic is) is likely damaged but for now check that Q9101C is not shorted, also check Q9102C to make sure it is not shorted.
                                "And no M1+ goes up to 217 max, it creeps its way up to 217v"
                                It sounds to me that your HF meter is too slow for the fast rising of the power supply Voltage. I do not expect the Feeding Voltage that feeds the boost converter to rise up slowly.
                                • R_J
                                  • 9535
                                  I would try checking that M1+ voltage without the led's connected, If the boost voltage IS there it should charge C0131 to the full 268v before discharging
                                  • x-solja
                                    • Jan 2021
                                    Hey All, not to highjack the thread, but I have the same TV, and have no backlights showing up as well.... I have been following along and testing as mentioned, however I do not get a hard set value when checking the M1+, or even the D9101.
                                    With CNL802 connected and TV powered up, I see constant changing values:
                                    M1+: 320, 311, 302, 293, 285 then back up to around 316, and back down through the same process.
                                    D9101 does the same similar process where it will jump all over the place up to 400, then huge drops down after that and just keeps looping around.
                                    I also notice when checking the lines across CNL802 (besides the varying voltages across each point), when I get to M9+ its showing 0V from then on...
                                    Any ideas, or more things to check? ...or is this a clear sign my Power is bad?
                                    Thanks,
                                    -X-
                                    • x-solja
                                      • Jan 2021
                                      Correction to the above... By M9+ i mean the 9th pin and M4+
                                      To add to the above, i found that if I bridge M4+ to M5- the leds will come on and everything works. ...So, i guess that would mean I have an issue with my M4/M5 led line
                                        • 12144
                                        • U.S.
                                        #39
                                        Any progress or update on this one DeatRaton?
                                          09-07-2024, 05:50 AM
                                        • shlomim412
                                          samsung ua55es6800 - no image
                                          by shlomim412
                                          hi
                                          having problem with samsung ua55es6800
                                          tv had backlight on, sound working - responds to the remote control but no image.
                                          check tcon board - had 12v in but no other voltages present.
                                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                          when leaving only left side connected - again no voltages and no image.
                                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                          kept trying to block less pins on the left ribbon cable...
                                          05-15-2024, 05:00 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                          09-06-2024, 11:40 PM
