Has anyone seen a curved line like this on an LCD screen?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    It's on the bottom left.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • budwich
    • Jul 2015
    • 3097
    Re: Has anyone seen a curved line like this on an LCD screen?
    my guess is that the set was taken apart to fix a problem on the "back side" and someone damaged one of the layers on the back.
    • petehall347
      • Jan 2015
      • 4437
      • United Kingdom
      looks like a scratch
      • RJARRRPCGP
        • Jul 2004
        • 6304
        About to take it back, because I fear I have a bad panel now.
        Just picked it up today. It's the 43-inch variant of the Samsung NU6900:
        https://www.rtings.com/tv/reviews/samsung/nu6900
        Arc A770 16 GB
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Just got an exchange for another one of the same manufacturer and model.
          There's a curved line in the lower-left, too! But, it's in a different spot.
          It's looking a lot like the way these get assembled, LOL.
          I like these TVs, because they're no signs of "RGBW", unlike the LG UH6100 series.
          Arc A770 16 GB
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Well, the second one has a line resembling the first one, but it looked shorter and was more horizontal. Along with 4K & HDMI troubles, apparently, I just sent it back and got the Ryzen stuff.
            Boy, the stock sucked at the West Lebanon, New Hampshire Best Buy on December 31!
            It was much better there on January 3, 2020, so I was able to pick up a Ryzen 3, an MSI B450 motherboard and DDR4 SDRAM!
            My first DDR4 ATX tower system!
            Arc A770 16 GB
            • Kiberge
              Samsung LH82QENELGC/EN Help needed - Static line on screen
              by Kiberge
              HI guys!
              I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
              I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
              the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
              This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
              04-22-2024, 11:28 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • almarhum
              To fix laptop screen vertical line by working on its EDP cable
              by almarhum
              Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
              As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
              05-07-2024, 02:12 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
