when i turn on, Philliips TV is not on
  • Nish
    replied
    Re: when i turn on, Philliips TV is not on
    I donot know
  • Nish
    replied
    That's what I thought
  • R_J
    replied
    Originally posted by Nish View Post
    I have 5v from IC901 to ZD907
    So you think that just because you have 5 volts on ZD907 you should have 5 volts for to supply the main board? Have another look at the schematic.
    in post #50 you said:
    I did, standby light blinking. I measure standby voltage. It becomes 1.8v not 4.48v.
    Where is this voltage coming from???????
  • Nish
    replied
  • Nish
    replied
    Originally posted by R_J View Post
    So do you have the standby +5 volts?
    I donot have 5V at C951A
  • R_J
    replied
    I solder 2 wire at C915A and measure.
    Now I removed from tv and measuring the voltage at C915A.
  • Nish
    replied
    from post #41 So you never did have this voltage?
    I had this voltage before I put it in tv and connected t mainboard. After this now I do not have it.
    Also: Where is this voltage coming from if you do not have standby voltage?
  • R_J
    replied
    from post #41
    Also when I fallow your drawing i got 5V
    Also:
  • Nish
    replied
    So NOW you don't have the standby AL5V any more?
    No I don't have the standby voltage at C951A. But I have 5v at ZD907
  • R_J
    replied
  • Nish
    replied
    That could mean one of two things, there is a problem on the main board killing the 5 volts or the power supply can't supply enough current.
    Is that measuring the standby voltage from ground to CN2 pin9 or across +&- of C951A. You could also check the standby voltage between pin9 and 11 on CN2
    The AL+5V feeds 2 voltage regulators IC3601(+1.25v) and IC3606(+3.3v) (page37) maybe one of them is bad?
    The one ic supplies 450ma and the other 200ma, so the power supply should be able to supply at least 1 amp. So you can try placing a 10Ω 2~5 watt resistor across the standby supply (or across C951A) This will draw about 500ma. and should not drop the 5 volts. If it does drop, then the power supply is at fault.
    Sorry to say I have only 0 017v at C951A, before I solder the resistor.
  • R_J
    replied
  • Nish
    replied
    Since you now have the AL+5V, why not install it in the tv and see if it works?
  • R_J
    replied
  • Nish
    replied
    What are you using for ground when you measure this voltage? Q905 emitter is connected to ground so use it to check the voltages in that area. AGAIN, the AL+5V does NOT use the same ground as the rest of the circuit. so stop using C951A as ground.
    If you want the AL+5V or C951A to have the same ground you need to connect pin 11 to pin 5,6,7,8 Or add the jumper wire J14 next to CN2, Just remember to remove J14 after testing the power supply.
    Sorry about it. I have 0V around that are.
  • R_J
    replied
  • Nish
    replied
    I want to remove the Q905, but I have still 4.48. While i unsolder it wonot effect any other parts.
  • Nish
    replied
    Q910, Q905 all 3 pin has 4.48v.
  • Nish
    replied
    The voltage that supplies PC902 comes from the AL+5V and connects to Q910 emitter. Q910 must be switched on by Q905 to supply the AL+5V to the collector and then to PC902, pin1
    This Philips POS service manual sucks and blows. If you look CN2 on Page 43, then look at page 42 CN3002 (this is where they connect together) it gets even more confusing. They swap the wires around so maybe pin 11(5vground) connects to the 12v ground at the main board?
    Yes it is confusing. I measured voltage Q910, Q905 has 4.48v and PC902 pin1 and 2 has 4.48v. Something short or I am using wrong ground. I am using negative lead of C951A as my ground.
  • R_J
    replied
