LG 65UH5500-UA Backlight flash on first power up only
    replied
    Re: LG 65UH5500-UA Backlight flash on first power up only
    PWR-ON is the PS-ON for the power supply boar, the LED driver board is used for routing that signal to the power supply board, it is not used by the LED driver circuit.
    For the backlights LED driver board to works it needs DRV-ON (BL-ON) and the P-DIM signal.
    So you are able to force on the Backlights by using the PS-ON signal, at this point the image, sound, and all other function of the TV are OK?
    What do you get at the P-DIM pin?
    What is the Voltage reading between the two leg of cap C409?
  • jason123
    replied
    Ok, further measrement on the LED Driver board yielded something intersting:
    The PWR-ON (pin 1 on CN402) has 3.45 V when I turn TV ON. DRV-ON (Pin 11) however has only 1.5 V. Momentary contact between these 2 pins (Pin 1 and Pin 11) turns the Backlight on and keeps it on.
  • diif
    replied
    Originally posted by jason123
    Very odd.. Brand new set of LEDs. With a tester, they all light up..
    I'm going to try replacing the LED driver board - Can't think of anything else.
    Swap LED1+ and LED1- with LED5+ and LED5- and see if the slightly different voltage reading moves.
  • jason123
    replied
    So this TV has 24 strips, each with 5, 3-V LEDs. There are 6 supplies on the LED Driver board, so each supply should be providing at least 60 V Differential for the Strips to turn on (I'm assuming each supply is driving 4 strips = 20 LEDs)
    The fact that I'm getting only ~40V differential tells me the LED driver is not doing its job?? Am I on the right track?
    Is there another control signal that tells the LED Driver to turn on other than the STB that's going to the power supply? Or is the Power supply turning the LED driver board on by simply turning on the 80V rails (From 60 to 88?) I see PWR_ON and DRV_ON on the Driver LED coming from Main board.
    Just trying to determine if this is a LED Driver board issue or still a power supply issue and I simply got a bad power supply this time too (2 bad supply boards)
  • jason123
    replied
    Not sure, maybe one weak diode in backlights??
    replied
  • jason123
    replied
    Ok, so
    When TV is on (STB = 3.4V)
    LED1+ to LED6+ are reading 88.25V
    LED1-, LED2-, LED3-, LED4- & LED6- are reading 42.26 V
    LED5- is reading 44.6 V
    When TV is off (STB = 0 V)
    LED1+ to LED6+ are reading 66.2V
    LED1-, LED2-, LED3-, LED4- & LED6- are reading 20.24 V
    LED5- is reading 22.3 V
    Is that meaning string LED5 has defect? I'm measuring on the back of the connector (Side that is directly connected to LED strips so no connector "connectivity issue" it seems
    replied
    I got derailed by the large caps having 385v all the time... never seen that before
    If i didn't misunderstand you #40, if STB is 0 v, then PFC Should be off. So why would large caps have 385v?
    That is why you need to check pin 22 of the SMPS/PFC IC, but as I indicated it may be stuck on, it the least of the problem right now, you need to find out why you do not have backlights.
  • jason123
    replied
    replied
    So the power supply is putting out the Voltages like it should, so the LED drivers board should be working as long as the LED driver board has all the control signals for the backlights to be on.
  • jason123
    replied
    Yes the 13.2 V is 10.5 v when TV Is off. When the STB is ON (3.4 V) the voltage jumps to 12.62 v (when the back lights happen not to turn on) and 13.34 v when it powers up properly.
    80 v is 66.4v when TV is off and ~82V when STB is 3.4 v
    replied
    Edit: Looking at the spec sheet of the SMPS/PFC IC combo, the PFC has enable pin 22 (see page 34).
    OPTO IC 1 looks to be for the PS-ON controller OPTO.
    BYW, are the 80V and 13V present when running the power supply board by itself?
    The key point right now is that if you do have the 80V output of the power supply board to feed the LED driver board with Error pin is LOW, and the LED driver board has all the control signals then the back lights should be on.
  • jason123
    replied
    So I replaced the IC.. same issue - with only AC connected to the power supply, I see 385 V across large caps, and 0 V on STB pin
    Bought another power supply board - it's acting exactly the same 382 V across large caps with only AC connected. Could it be that both boards are bad? or are they supposed to work this way??
  • jason123
    replied
    Is it the NXP Pfc IC, or...
  • jason123
    replied
    Originally posted by budm
    So to be clear, when the TV is OFF, the Voltage on the main cap stay at 385V?
    Correct...
  • jason123
    replied
    Not anymore. Recall i replaced the full LED Set and fail signal is 0 v
    replied
    At this point , the FAIL pin is the issue since you have to GND it to get the TV to come on, need to trace out the FAIL pin to see where it leads to as RJ suggested.
    https://www.shopjimmy.com/lg-cov3369...er-supply.htm#
    https://assets.shopjimmy.com/media/c...401-bottom.jpg
    replied
  • jason123
    replied
    With everything connected.. StB is 3.4 v when tv is on and 0.057 when tv turns off
    replied
    So does the STB change state when TV is turned on and off with everything connected?
    Yes the main board control the STB signal.
    The STB control is being routed through the LED driver board.
  • triplefour
    TCL 75S421 has sound but no backlight not even a flash
    by triplefour
    TCL 75S421
    PSU BOARD: 40-L402H8-PWD1CG
    it shows not even a flash of backlight when powering up.
    but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
    testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
    unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
    i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
    with mb connected, PSON...
    11-17-2023, 09:54 PM
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • ekozeko333
    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
    by ekozeko333
    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
    🔥 The Problem Started After Suspected ESD/PD Fault
    I experienced a power issue or ESD event through a USB-C charger
    After that, the NX20P5090 power switch was visibly burned and was replaced
    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • crozoki
    Philips 65PUS6554/12 one time backlight flash
    by crozoki
    Hello
    I have Philips 65" TV (65PUS6554/12).
    Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
    Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
    Power board TPV 715G9187-P01-008-001S
    Main Board 715G9907-M01-B03-005K...
    09-03-2022, 05:47 AM
