Re: LG 65UH5500-UA Backlight flash on first power up only
Test at CN2.
Ok, so this TV has the LED driver board between Power and Main. Are you after the voltages coming out of the PS card or if the main is getting the power, just so I know which side to measure?Leave a comment:
Do #3 below now that you have the backlights working.Leave a comment:
Still occasional no backlight... as expected
Power supply maybe or LED Driver board.. or mainboard?Leave a comment:
Thanks nomoresonys.. I did firmware update and doing the factory reset now.Leave a comment:
Maybe try a factory reset and firmware update, might not fix it but it don't cost anything.Leave a comment:
Hi there.. Applogies for the delay in checking here.. here is an update:
So, with the Fail line tied to COM, I took the panel apart again, and sure enough, 2 strips where off. I replaced the entire set with brand new LEDs.
Tested it a couple of time, and it's as bright as ever. Removed the Fail pin jumper to COM, the unit powers up just fine.
I buttoned things up, put the cover back and and watched TV all night (Awesome picture) One thing I noticed is the Chime when you power up, is not smooth.. it's choppy, disconcerning, but it was working so I didn't care.
Second morning I powered it up, chime came on.. but no backlight. tried few times. upglugged from wall.. tried again few times.. then finally it started working again. No physical movement of the TV (So something loose or bad solder joint is not what seems to be the problem. ).. it worked find the rest of the evening.
Today.. I started it.. Chime and no backlight. again.. tinkered with it.. and it's on again.
I took the cover off and replaced the Wifi module (someone seems to have suggested it in another post).. no luck. applying power and removing power seems to be what turns the backlight on. Keep in mind that even when it doesn't turn backlight on, the Chime is coming on - unlike what it did when the backlight had dead LEDs.
Thoughts? Suggestions??Leave a comment:
After looking at the boards again, it could be that the fail signal could come from the led driver board, so an error with the panel led's could trigger the power supply to shut down. maybe post the number of IC400 on the led driver board so the fail line can be traced.
I see some people are also reporting poor connection problems either on the plug that connects to CN403 on the led driver board or poor connections between the lead wires and the strips in the panel. might be worth checkingLast edited by R_J; 12-07-2019, 09:34 PM.Leave a comment:
Is the 80 volts also low on the power supply? the Fail signal circuit monitors both the 80v and the 13.2 volts and if they are low it activates the Fail line.
You might also want to check the voltage on the main filter C57/8/9 If it is low it could be that the pfc circuit is not workingLeave a comment:
You may still have an LED or two failing at higher current. Can you measure the LED output voltages with the backlights forced on since a lower voltage on one string would indicate a short on that string. I normally turn on the TV with the panel disconnected to observe all the leds. Delayed turn on and flickering are signs of imminent failure.Leave a comment:
Hi Folks,
I saw a similar post (https://www.badcaps.net/forum/showth...5UH5500&page=3) but it didn't really state the issue, so I'm giving it another shot
Got this TV, and upon firs power up, the backlight flashes on, then off. Classic symptom of Bad backlight LED. Ordered a set and opened it up without making any measurement (cause I was just sure!!!) and after over 90 screws, all LEDs tested out ok. Repeated the test to make sure - and no question, every single strip tested out fine (I just used a 90V supply with current limit resistor - Home made)
Buttoned it back up and started taking measurements. The LED Driver board shows DRV_ON and PWR_ON and 13.2 V pins (accessible)
Upon first power up, the PWR_ON goes to 3.2 V, then DRV_ON goes momentarily to 3.2 V, backlight comes on, the main board has RED LED that comes on, Optical port LED comes on, then all come off (including PWR_ON and DRV_ON SIGNALS) - That's it. Second turn on attemp using power button takes PWR_ON to 3.2 V, DRV_ON goes to 57 mV then back to 0. PWR_ON goes to 0 then back to 3.2 and stays on no matter how many times I press the Power button. Backlight never comes back on again, unless I hard reset (unplug from wall then reconnect power)
The 13.2 V on the Driver board are 9.25 V, never reach 13.2 V (mislabeled?)
Could it still be backlight like everyone seems to be leaning to?
On the Power Supply Board, there is a Fail pin.. someone said short it and power up.. I did.. and Voila.. it's up and running, beautiful backlight and picture.. What does that mean? how can I clear that "Fail" state so I can power up without this jumper?Last edited by jason123; 12-07-2019, 12:20 PM.Tags: None
by triplefourTCL 75S421
PSU BOARD: 40-L402H8-PWD1CG
it shows not even a flash of backlight when powering up.
but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
with mb connected, PSON... -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM -
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
by crozokiHello
I have Philips 65" TV (65PUS6554/12).
Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
Power board TPV 715G9187-P01-008-001S
Main Board 715G9907-M01-B03-005K... - Loading...
