TOSHIBA 48U7653DB powers up, no backlight
  • finntricky
    • Jan 2014
    • 449
    Hi
    i have the above tv, that i got as spares/repairs, yes it boots find but no back lights, can see pic with bright light,
    so i knew some of the LED's have blown, stripped it down and found 7 LED's out, replaced and now all working, but the power board now seams at fault, only getting 79 volts for each set of LED's, that is not enough for a set of 3 strips that shows needing 92 volts. there are 2 sets of 3 strips in the set.
    thinking it was a board issue, i ordered another from EBAY, and tryed that, but still no back light and only 79 volts for each channel, same as my board, so i now need help. board is 17IPS20, and yes i know there is so many versions of this board, and can't seem to find any info for pin outs and volts.
    took some pics, but they are not great, will see if i can get better latter.
    by the way, the pic with the board number and the LED connector plug, you will notice that a black neg wire is missing, i have used ground of the chaise as could not get a reading from it when testing the POS conection next to it, but grounding the black wire gives me a reading of volts.
  • CapLeaker
    Leaking Member
    • 8352
    Re: TOSHIBA 48U7653DB powers up, no backlight
    the backlight leds are current controlled, not voltage controlled. When you turn the TV on, do the backlights come on for a second, then turn off again, or are they not turning on at all? How much DCV do you have across the main 450V filter capacitor with the TV running?
    • finntricky
      • Jan 2014
      • 449
      393 volts, led's did flash once, when turned on, but not doing that now,
      • yokoono
        • Apr 2010
        • 515
        You have 2 red and 2 black wires. The red wires go to + power for backlight. The 2 blacks DO NOT GO TO MINUS (GROUND) but to the driver or 2 mosfets. You cut a black wire and laid it on the ground. You left an arm of the driver without the burden. It notices a problem and gives the processor command to turn off the backlight.
        Glue the black wire back in and test. Measure the voltage on the strip between the red wire and the metal housing of the TV.
        Put the measuring instrument on the red wire and turn on the TV. See what is the maximum voltage read by the instrument.
        Example
        https://www.youtube.com/watch?v=2pyuXwNkBMA
        https://www.youtube.com/watch?v=6hQOiN4-XPk
        • finntricky
          • Jan 2014
          • 449
          Example
          already said volts are 79v, red wire is + and orange wire is - and the other 2 wires are brown + black -, same volt with LED's pluged in, or unpluged if i put my probe on brown + and black - i get no reading, but if i put probe on red + and orange - i get a reading of 79 volts, hence why i removed the black wire and put to ground and then have a reading of 79 volts from brown +
            Do not ground the black wire of the LED to the chassis, the LED return wire is not connected to ground directly, it goes to ground via PWM controlled MOSFET and current sensing resistor.
            I need to see good clear focus straight shots of the whole top and bottom side of YOUR power supply board.
            Put the black wire back in place, them put black probe of the meter to the chassis, keep red probe on the Red wire plus then turn the TV on to see how high the Voltage jumps up to and wait 10 seconds to see how low it goes back down to then turn the TV off, do the same on the brown plus, we are trying to see what the Voltage at the + wires of the LED when TV is first turned on.
            • finntricky
              • Jan 2014
              • 449
              goes to 79 volts, and no more, just sits there at that voltage untill turned off, and then volts drop
                It sound like the BL-ON is not present to turn on the boost converter circuit for the backlights or the boost converter has failed, still need pictures as requested.
                BTW, you did put black wire back in place, correct?
                • finntricky
                  • Jan 2014
                  • 449
                  yep, wire back in plug, here are pics
                  • finntricky
                    • Jan 2014
                    • 449
                    been doing a bit of testing around the LED controler, found 2 caps showing short and 1 diode,
                    uploaded a pic, just got to find out if all faulty or just 1
                    • finntricky
                      • Jan 2014
                      • 449
                      turns out, that all are fine when tested of the board, it can only be the chip that is the problem ?
                      what do you think ?
                      • CapLeaker
                        Leaking Member
                        • 8352
                        take the ic off the board and see if the short disappears.
                        • yokoono
                          • Apr 2010
                          • 515
                          Did you do what he writes here? Measure, compared to the ground, if there is voltage on the BL ON pin when you turn on the TV. About 3V.
                          • finntricky
                            • Jan 2014
                            • 449
                            all fixed, up and running, changed LED controler IC MP 3394s and MDD 14N25
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • stylishconsultant
                              un60j620dafxza - Samsung No Display Problem
                              by stylishconsultant
                              Hi All,
                              Need help.
                              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                              09-04-2024, 03:26 AM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                              09-06-2024, 05:27 AM
