Samsung UN60KU6270FXZA dead, no stby light, diagnostic complete, a couple questions.
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hello everyone, long time no see! I have a few questions about a power board I'm working on and was hoping to field some answers.
    MAKE: Samsung
    MODEL: UN60KU6270FXZA
    VERSION: EA01
    POWER BOARD P/N: BN44-00808D
    SELLER COMPLAINT: Sound volume became unstable for a brief instance, TV shut off, became unresponsive and appeared dead.
    INITIAL INSPECTION: Main fuse FP801S (T8.0AH/250V) open, Thermistor NT811S 7.5ohms across legs, board there has a slight brown discoloration, rectifier diode indicates short across DC legs, main caps indicate short across both legs, MOSFET QP801CS (60R360P) indicates short, Diode DP807C (SF10A600HPL) indicate short, MOSFET QP802CS (60R360P) indicates short on drain and source. Items circled in red.
    DIAGNOSTIC FLOW: Remove QP801CS, tests short. Re-test DC legs of rectifier diode and legs of both main caps, short cleared. Rectifier diode tests OK. DP807C still indicates short, QP802CS still indicates short on drain and source. Remove DP807C, tests short. Re-test QP802CS in-circuit, short on drain and source cleared. Test all components off gate of both MOSFETS, all appear good.
    ACTION TO BE TAKEN: Replace QP801CS, QP802CS, DP807C and main fuse.
    ACTIONS CONSIDERED: Precautionary replacement of NT811S
    Questions:
    With QP801CS, DP807C shorted and components off both gates of QP801 and QP802CS testing OK is it necessary to replace PFC IC ICP801 (6BA3G2M SPC1012T, circled in yellow)?
    Have I missed anything else I should be checking with the above failures present?
    Thank you everyone for the help!
    They call me......."threadkiller"
    Re: Samsung UN60KU6270FXZA dead, no stby light, diagnostic complete, a couple questio
    I would replace the PFC IC too, it is not worth taking an chance of blowing the new parts you replace.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Thanks budm! One last question. Is the clear silicone surrounding the PFC IC required to be replaced after service? I'll have to scrape it off to replace that IC. If so can you suggest a product for that?
      Wishing for you a happy Thanksgiving!
      • Storyteller12
        • Jun 2020
        • 625
        I have the same problem and have replaced the mosfet. However having a hard time finding
        SF10A600HPL Or replacement.
        Maybe I’m searching wrong, but cannot find a suitable replacement. Any help would be appreciated. Thanks n advance.
        • diif
          • Feb 2014
          • 6978
          • England
          Maybe I'm searching wrong, but cannot find a suitable replacement. Any help would be appreciated. Thanks n advance.
          Search for SF10A600H.
          • Storyteller12
            • Jun 2020
            • 625
            Will do. Thanks for the reply
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4540
              • Italy - Milan
              check the varistor...
              • Storyteller12
                • Jun 2020
                • 625
                Are you referring to the thermistor mentioned in the original post?
                If not please specify the varistor you mention. Sorry I'm kind of a noob at all this, teaching myself along the way.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4540
                  • Italy - Milan
                  near the AC input, that green disk, must show open in ohm..
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Thanks for the reply. Will check that as well
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Ok. The. Varistor is good. However I replace the Mosfets and the double diode rectifier and when powered up without main board hooked up I get backlights flashing on and off.
                      Good news is the fuse doesn’t blow anymore. Can someone confirm the parts I used are correct.
                      I could not locate the original parts so had to find replacements.
                      For the 60r360p Magnichip I relaxed both with IPA60R360P7SXKSA1 from mouser and for the SF10A600H I replaced it SFF1008GA C0 from mouser also.
                      Appreciate the help
                      • Storyteller12
                        • Jun 2020
                        • 625
                        Also I can confirm it’s not the backlights as I have another power board I installed and the tv works just fine.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4540
                          • Italy - Milan
                          you have probably an intermittent short on secondary, first disable the backlight by pulling down the bl on command, then test the psb to mb connector without and with dummy loads, if all is well check mosfet/diodes of the led driver section, if not check all diodes, if good replace el. condensers
                          • lotas
                            • Jan 2016
                            • 4865
                            • Russia
                            If the backlight blinks, then most likely the PFC does not work (it does not hold the load), what is the voltage on your CP810, CP811 capacitors?
                            • Storyteller12
                              • Jun 2020
                              • 625
                              Plugged it in and tested the main caps cp810 and power was fluctuating up and down to 0.
                              Right after that test sparks flew. Fuse blown amd 1 of the mosfets I replaced 60s360p blew up.
                              Checked the other mosfet and the rectifier I replaced and they are still test good.
                              • lotas
                                • Jan 2016
                                • 4865
                                • Russia
                                There is a high voltage on these capacitors, provided that the input voltage AC 220v on them should be in standby mode DC 300-320v, in working mode about DC 400v (PFC (Power Factor Correction) starts to work), and the fact that sparks have occurred, then rather you closed these conclusions "+" and "-" among themselves.
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  I realized as the OP I didn't update this thread. I had a TV come in for parts that had this power supply in it. I used its power supply to repair this TV.
                                  Did you accidentally short the + and - on the main capacitors? If not then it sounds like the PFC IC may be short
                                  Main cap voltage in stand-by is around 165v DC and 380-400V when the TV is on.
                                  Sorry I haven't been so good with updating my posts. I recently had a stroke and have been in recovery.
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    I didn’t short anything out when it blew up. I took the first measurement the had a phone call.
                                    While I was on the phone it blew up. I suspect you are right about the pfc ic and when I was removing it I had the board “popcorn” I believe is the correct word around the ic.
                                    I’m guessing the boards trash now.
                                    At least I had a backup power supply. I was just trying fix this one.
                                    • DynaxSC
                                      Extreme High Current & Low Voltage Short Killer ??
                                      by DynaxSC
                                      Hi Folks
                                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                      After taking off the socket, the shorts dissappear again.
                                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                      10-15-2024, 10:13 AM
                                    • csberti03
                                      Bmax B7 Power Mini PC interesting short diagnostic
                                      by csberti03
                                      Hi!
                                      I have this mini pc that doesn't want to start.
                                      When I plug in the charger it goes into protection mode.
                                      I check the input pins in resistance mode and they are not shorted.
                                      But in diode mode its 0.174V
                                      When I opened it up I saw something new, no input mosfet, just big diodes next to the charging port. I checked on the coils for shorts but didn't find anything suspicious. Only the CPU coils have low resistance but that should be normal because it's an 11th gen I7.
                                      I injected some voltage to find the short but the board was only...
                                      08-24-2024, 03:13 PM
                                    • Stephen
                                      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                      by Stephen
                                      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                      02-06-2025, 12:03 PM
                                      Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                      Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                      various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                      Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                      trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                      what is wrong with your PC in just seconds. It saves you time and money.
                                      Our new and improved design...
                                      11-01-2024, 06:29 AM
                                    • adelfr2009
                                      HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                                      by adelfr2009
                                      I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                                      After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                                      09-28-2025, 10:21 PM
