LG 50LF561V LEDs
Re: LG 50LF561V LEDs
So they're not 6v ? these are 6v, whole strips but described as 6 volt: https://www.ebay.com/c/1264935641Comment
They are for a different TV are they not?? A 55" model?So they're not 6v ? these are 6v, whole strips but described as 6 volt: https://www.ebay.com/c/1264935641
Mine is LG 50LF561VComment
Says 55LF561V, I'm thinking same led but those strips would be a little longer, you couldn't use those strips of course but I think vinceroger is right about them being 6 volts.Comment
the seller are wrong the photo he put on are 3V. as OP
we look on his other offer... no V written at all.
as i wrote on my post 4 LG are 4.6V, however it measured always how much it reserve current and how much it forward to next led..Last edited by Diah; 11-25-2019, 04:17 PM.Comment
once your led tester arrives you can test a good led and see what the voltage isComment
May be a stupid question, but can they be tested without the tester? I.e of using battery equal to 3v, a 3v will illuminate but 6v wont?? Or am I totally missing how they work in that regard?Comment
Just if that is the case, ive just tried with battery on a 3v LED and it illuminated, and also tried on a good one of these ones, and it doesnt. Yet it does illuminte with a 9v batteryComment
5 x strips of 4
5 x strips of 5
Pic attached as requestedComment
so total 45 Leds on 2 line, if they are 6V mean each line 135 V. and this so much
if they are 3.V mean each line round 67 V and this is normal.
however you can take look on the 2 caps near to the led socket and tell the value and the working voltage... i guess they will be 150V...Comment
Here are the capsso total 45 Leds on 2 line, if they are 6V mean each line 135 V. and this so much
Doesn't seem that hard to me: https://www.ebay.com/itm/LED-Backlig...-/283501847659Comment
But again, they are full strips, not individual LEDs??Doesn't seem that hard to me: https://www.ebay.com/itm/LED-Backlig...-/283501847659
Does say in the description that they are 6v, but I dont have much faith in eBay sellers after today lolLast edited by Bloopeta; 11-25-2019, 04:53 PM.Comment
i am afraid i am wrong with 3V. if the double cap of 350V are related to LED back light say different stroy.. could you please post clear photo on the back side of the led socket little more covered area to follow the line all caps on the photo you post earlyComment
By everyones input, and powers of deduction lol, im thinking these are the ones lol
https://www.ebay.co.uk/itm/20pcs-353...IAAOSwFZZb8Vw0Comment
🤣🤣 oh well I did say my eye sight wasnt great lol
Thankyou everyone for your input, much appreciated, got there in the end n theyve been ordered.Comment
diff, before 4 years i bought from aliexpress and they was 4.6 voolts. i cant find the seller any more... but now all write 3 or 6 v. and this wrong... as no one mentioned the current of sure if we use 6 it will fit to work... but the spot if the lumen are higher and if the forward current are higher so the old one will die soon.Comment
by mc900fthannaSo... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
by lmcancuHi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
Instead of putting it back together I decided to replace... -
by FirentiosiThanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
The issues are as follows: the...2 Photos -
by anupkg1985Hi,
I have this Insignia tv with most of the led's damaged. I'm not able to find the replacement LED strips for the same. The numbers marked on LED strips are -
LB-GM3030-GJBETTY504XBBB19. Please find the photo for the same. Can somebody help finding replacement/equivalent led strips for the same.... -
Assuming...7 Photos - Loading...
