Haier 49UF2500
  • dprit
    • Jul 2015
    • 49
    Haier 49UF2500
    This set has no BL. I can see the display using a flashlight. There is no audio because I can't tell what input it is on. My question is there is 247v on the connector going to the back lights. That seems very high. Could the LEDS be open? Using a SJ Led tester, it stays on 333v also and no backlights. Does anyone know what is used in this set for LEDs?
    Re: Haier 49UF2500
    You will get a lot more help if you upload good clear pictures of the whole backside of the TV showing all the boards so we see what we are dealing with.
    • dprit
      • Jul 2015
      • 49
      Re: Haier 49UF2500
      With the back light voltage from the PS high and also with the SJ back light tester, I figured a open led strip. And after dis-assembly, I did find one of the strips open. I'm waiting on a replacement strip.
      • neilc6
        • Nov 2015
        • 1550
        Re: Haier 49UF2500
        Just repaired a 55UFC2500. Curved but panel is actually flat and flexed to fit in the curved chassis. Had one LED open. You need to keep the picture mode to Energy Saving (50%). Vivid is 100% and will burn out the backlights. Backlight can be set in service menu under panel settings (menu-1-1-4-7) with tv on. I find Energy Saving a little low so set to 65 which is saved in User mode. Need to do this on all inputs.
        • nubinator
          how can i test individual leds without tester
          by nubinator
          Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
          I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
          10-25-2022, 11:05 PM
        • Pipolups
          Corsair K70 LUX RGB dying LEDs
          by Pipolups
          Hi there !
          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
          10-08-2024, 11:58 AM
        • lmcancu
          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
          by lmcancu
          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
          Instead of putting it back together I decided to replace...
          04-01-2023, 01:11 PM
        • pni
          Backlight panel diffuser melt by backlight leds broken
          by pni
          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
          10-12-2025, 12:08 AM
        • Lifeisfun
          Trying to troubleshoot DDR4 SODIMM slot with slot tester
          by Lifeisfun
          Hi folks!
          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
          Eventually I discovered that it was related to moving the laptop.
          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
          I removed the board got one of those memory slot testers...
          06-04-2025, 02:26 PM
