Philips 32PFL3606/58
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: Philips 32PFL3606/58
    It says 49uF
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The TNY277PN must be working since it generates the 5V output. In your case a little low at 4.74V.
      However it also generates the voltage to run IC808 and IC902 via another winding from the same transformer (T902) which is then rectified and smoothed by D904 and C912 but only measures 10.8V.
      IC808 requires a minimum of 11.5V and typical 12.5V to turn on which it's not getting. The voltage at D904 is too low which I think may be the reason that it is not running IC808 to boost the voltage to 380V
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Originally posted by nbdy
        It says 49uF
        Can you check it's ESR?
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          Nope,can only change the whole capacitor
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            It would be worth trying that.
            • nbdy
              • Aug 2015
              • 162
              • Croatia
              #26
              Still the same 10.80V
              Faund the ESR meter,it says 0,75 ohm,0.7% loss
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                Sorry but I'm now out of ideas at the moment. Perhaps others can offer further advice.
                • nbdy
                  • Aug 2015
                  • 162
                  • Croatia
                  #28
                  thx for now ..
                  If you got new ideas let me try :-)
                  Any other advice is welcome 2
                  • nbdy
                    • Aug 2015
                    • 162
                    • Croatia
                    #29
                    Any one with some idea ???
                    Does any one know where to buy another PSU ... Looked on ebay there is none ...
                    thx
                    • R_J
                      • 9625
                      When checking voltages in the primary side, use the large (100µf/450v) capacitors negative lead for ground.
                      Check the voltage across the large capacitor, in standby the voltage should be around 325vdc. When you connect S/B to +5v that voltage should go to around 380vdc. check it. and if it does not change, check pfc ic, using hot ground check the vcc voltage on pin8 of ic909, it should be around +20vdc
                      • nbdy
                        • Aug 2015
                        • 162
                        • Croatia
                        #31
                        @R_J : Got 325V on the capacitor in both states with the S/B on 5V or not ...
                        The IC909 has 10V on pin 8 ..
                        • R_J
                          • 9625
                          The PFC circuit is not being turned on. If it was, the voltage on the main cap would icrease. I suspect you are not getting 20v VCC, this VCC voltage also supplies ic902 pin6.
                          The 10 volts on IC909 pin 8 is supplied by it's internal startup cell. Check the voltage on Q903, The emitter should have ~25vdc, the base is controlled by optocoupler IC905. When IC905 is ON, pin4 will be low turning on Q903 which supplies the +20dc for IC909 and IC902 VCC
                          • nbdy
                            • Aug 2015
                            • 162
                            • Croatia
                            #33
                            I have 13.3V on Q903 ...
                            • R_J
                              • 9625
                              Is this the voltage on the emitter? This voltage needs to be higher, check that C912 is not bad, also ZD910 and ZD903 could be bad and zenering at too low a voltage
                              • nbdy
                                • Aug 2015
                                • 162
                                • Croatia
                                #35
                                The C912 Shows 49uF ESR 0.54 Loss 0.8%
                                The ZD910 shows 720 in one direction, 6V reading on board or -6V turning the probes
                                The ZD903 shows 717 in one direction, 4.3V reading on board or -4.3V turning probes
                                Diodes desoldered from board for testing ...
                                Could it be that the IC901 is not OK
                                • R_J
                                  • 9625
                                  If ic901 was bad you would not have any +5v standby voltage. You can't check the zener point of zener diodes with a meter. Have you tried replacing C912? Have you checked if R918 is ok?
                                  • nbdy
                                    • Aug 2015
                                    • 162
                                    • Croatia
                                    #37
                                    The R918 showing 4R7 ...
                                    The C912 replaced,all the same ...
                                    • R_J
                                      • 9625
                                      If your +5v standby is ok. disconnect thge s/b line from 5vstb, now check the voltage across IC906 pins 3&4. There should be some voltage there. Now connect the S/B line to +5v and see if that voltage goes to 0 volts. It should if the optocoupler is working.
                                      • nbdy
                                        • Aug 2015
                                        • 162
                                        • Croatia
                                        #39
                                        I have 970mV on both states with S/B on 5V,and without the S/B on 5V ...
                                        and without the ENA to 5V connected ...
                                        With ENA to 5V all the same - 970mV
                                        So i think changing the optocupler maybe be the solve ... will try tomorrow ...
                                        • R_J
                                          • 9625
                                          Check the voltage across IC906 pins 1&2, that will tell you if the internal led is being turned on or not. Use the same method for testing by disconnecting and reconnecting S/B to +5v
                                          You can also monitor the voltage across C912 and try shorting IC906, pins 3&4 to see if the voltage changes and goes up to around +20v
                                          There could be a fault wiith Q908 not turning on the optocoupler, when S/B is connected to +5v, Q908 drain should go to 0 volts, the same with Q907
                                          • Sharpa
                                            Repair attempt Philips 55OLED804/12
                                            by Sharpa
                                            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                            The symptoms when bought: Philips logo appears then tv turns off
                                            Things tried so far:
                                            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                            11-22-2025, 08:30 AM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
