Philips 32PFL3606/58
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    #41
    Re: Philips 32PFL3606/58
    Changed the 817 optocupler (IC906) but the same result,now i have 1V ...
    Will try to short it ...
    The voltage on 1&2 is also 1V on IC906 ...
    When I short the pins 3 & 4 I get 5V instead of 10V ... on 50UF/50V,and on Q903 i get 5V instead of 0.7V
    • R_J
      • Jun 2012
      • 9624
      These voltages need to change when S/B is connected to +5v, If they do not, then it is likely the circuit is is just remaining in standby.
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        #43
        When I short the pins 3 & 4 I get 5V instead of 10V ... on 50uF/50V,and on Q903 i get 5V instead of 0.7V
        THe voltages don't change with or without S/B connected to 5V
        • R_J
          • Jun 2012
          • 9624
          I have no idea what you mean about Q903. there are 3 leads on that transistor which leads are you measuring 5v instead of 0.7v? If it is the BASE? That would make sence if the IC905 opto is not being turned on.
          Why don't you start by making sure the two fets, Q908 and Q907 are working first. If they don't switch. nothing else will either.
          • nbdy
            • Aug 2015
            • 162
            • Croatia
            #45
            Sorry had a hard working week ...
            Tested the fets,they seem ok onboard test ...
            Should I have some specific voltages on them ???
            • R_J
              • Jun 2012
              • 9624
              The fets source will be connected to ground, the drain will likely have close to +5 volts on them, when the S/B pin is connected to the 5v standby, the drain should go low.
              • Sharpa
                Repair attempt Philips 55OLED804/12
                by Sharpa
                I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                The symptoms when bought: Philips logo appears then tv turns off
                Things tried so far:
                1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                Yesterday, 08:30 AM
              • alro7779
                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                by alro7779
                Hello, guys!
                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                09-14-2025, 12:25 AM
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • double_DD
                Philips curling iron - is this a common AC cable?
                by double_DD
                Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                08-18-2025, 10:04 AM
              • janos6662000
                Philips 47PFS7509/12 LCD TV problem
                by janos6662000
                Hi
                I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                When i applied cable signal to check image, i had normal picture, but TV was restarting.
                I downloaded original firmware and applied the update, but the problem remained.
                From a colleague i received a "factory package software" which is a lot bigger.
                I made another firmware update, but still did not solve the problem.
                Somewhere on the way the error got worse, because at the moment the...
                08-12-2025, 12:54 PM
