RCA RTRU5028 No Backlight
  • neilc6
    • Nov 2015
    • 1550
    Owner reported he had it diagnosed as bad backlights. US model number may be RTRU5027. Checking the backlight connectors with an LED tester, the two wire pairs had the same voltage. After opening up the tv, all the leds tested fine. Then I noticed the burnt FET on the power supply board. Source pin was blown out. There are two on the hot side (not heatsinked) and they look mirrored but most of the components on the burnt side seem damaged. I can match the resistors but the SOT23 transistor is suspect and the diode is bad and can't read the markings on both. Power supply board is HSL55D-2S9 and a bit expensive for a used one.
    LED driver IC is TI UCC25710.
  • neilc6
    • Nov 2015
    • 1550
    Re: RCA RTRU5028 No Backlight
    I've identified all the blown parts.
    Q506 TF5N50 (NCH 500V 5A)
    C523 220pf 1kv
    Q504 (2T marking) MMBT4403 PNP
    D509 (T4 marking) 1N4148 100V 250ma
    R506 240 ohm 1206
    R533 300 ohm 1206
    R529 10K 0805
    It looks like Q507 shorted blowing up Q506.
      https://www.badcaps.net/forum/attach...2&d=1569376944
      It looks like one of the upper MOSFET Gate pin has bad solder joint so may not have turned off so when the bottom one turned then it caused the damages.
      Q504/505 are for Gate's discharge.
      • neilc6
        • Nov 2015
        • 1550
        Q504 was blown but Q505 I replaced anyway. Assuming both are PNP since they appeared wired the same. Going to increase the FETs to 8A from 5A but may not be necessary if problem was the cold joint.
        R533 is 30 ohm. The second one R528 was open as well
        • neilc6
          • Nov 2015
          • 1550
          I was pretty close to giving up and buying a new ps board. Installed all my parts, had a standby light and the fuse popped when I turned on the power. Checking for shorts again, I found D401 shorted (SF26, 400V/2A). I replaced temporarily with a MUR460 and replaced fuse with 2.5A instead of 4A since that was all I had. Fuse blew again and no standby light. Checking again, I realized Q506 and Q507 had shorted again so replaced those a second time. TV finally turned on. Guess the original problem was D401 and not the cold joint and the FET blew before the fuse originally. Made Digikey cutoff so should get the proper fuse and diode tomorrow.
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • willis6732
            Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
            by willis6732
            This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
            Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
            The Driver board looked pretty toasty in the LED Driver Area.
            So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
            12-17-2024, 04:09 PM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
