Panasonic TX-L47WT50B stby LED only
  • Trevtron
    • Apr 2015
    • 124
    • Portugal
    Hi all, looking for some guidance on this sick set someone asked me to look at.
    According to the owner's wife, it got stuck displaying the 'Viera' logo, then when it wouldn't come on the standby led flashed 13 times.
    It has done neither of these tricks for me. When plugged into the mains the led comes on red, pressing the power button on the remote starts it flashing green for a few seconds then it stays solid green. Any further presses extinguish the led. There is no sign of life from the TV itself. No audio (not even a start-up click from the speakers) and no backlight.
    Ordinarilly I would check a few voltages before posting - sometimes this even reveals the fault. BUT I can see no voltage references on any of the boards so apart from the obvious inverter outputs to the leds (which are zero volts) I didn't check any further.
    Are there any other obvious things I can check?
    TIA.
  • douha
    • Sep 2014
    • 44
    • maroc
    Re: Panasonic TX-L47WT50B stby LED only
    You can verify inverter 24v gnd blon
    Power supley 24v external input
    • Trevtron
      • Apr 2015
      • 124
      • Portugal
      This would be easy if the boards/sockets were labelled, unfortunately Panasonic has decided not to do this.
      • JohnML1975
        Panasonic TH-P65ST60A no STBY light no backlight no power
        by JohnML1975
        Hello All
        Started working on this TV today
        As I remove the back will share some photos and findings
        The problem I am having is in the title of this thread
        I still need to proceed my trouble shooting
        Started a thread so that I can share with all
        Any inputs are welcome
        10-25-2025, 04:50 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
