XVT3D554SV - Blinking Amber / White - PS Damage
  • jason123
    • Oct 2015
    • 1154
    Re: XVT3D554SV - Blinking Amber / White - PS Damage
    I lifted on leg of D1 and no effect. Q5 Collector is still bouncing around as is STBY 5 V
    • NConstantinou
      DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
      by NConstantinou
      I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
      WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
      BIIOS PINS 7,8 I HAVE 3.3V
      IS THE PROBLEM ON MOTHERBOARD OR BIOS.
      08-21-2025, 03:23 AM
    • shahnld
      Sony kdl 65xg9505 green amber blinking
      by shahnld
      Good Day.
      I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
      i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
      green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
      01-03-2024, 03:05 PM
    • crewdog
      Hp 15-dy2087nr white lights blinking
      by crewdog
      Board DAOP5HMB8F REV F
      Model OPSH
      No bios battery on board
      Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
      Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
      and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
      Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
      10-25-2023, 03:08 PM
    • ahmarzo
      Hp 15-cs laptop 5 times dc jack blinking white
      by ahmarzo
      I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
      First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
      Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
      But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
      12-28-2024, 04:46 AM
    • noipi
      DELL INSIPRON 14 No power blinking orange/white
      by noipi
      i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
      05-06-2025, 08:08 PM
