Sharp 32CHF5111K (TP.MS3463S.PB711) Fault
  • sickboy
    • Jun 2015
    • 86
    I'm wondering if anyone can help me out with this repair?
    Nice Sharp 32". This powers on and the little LED flashes red for a few seconds, then turns white as normal to signify that it's now on.
    There's no backlight though and as far as I can see there's no image on the screen. I've stripped the screen and tested the backlight strips and they all light up ok using the tester. Another symptom is that the TV will not switch to standby.
    Voltages I tested were 330v across mains filter cap and 42v between the backlights positive output and ground. There's no boost voltage when first powered on either. All diodes test out ok.
    Any help gratefully appreciated.
  • CapLeaker
    Leaking Member
    • 8347
    Re: Sharp 32CHF5111K (TP.MS3463S.PB711) Fault
    Put your TV back together, unhook the main board from the PSU and force the PSU on. Use 1k resistors and jump STBY over to PSon, BLon and maybe even the DIM signal. Plug the TV in and the PSU should be fully on and the backlights too.
    • R_J
      • 9611
      How do you expect him to disconnect the main from the power supply when it is a single board???? get out the saw?
      Check if you have +12v on UB801 pin 1, that is the ic's vcc
      • sickboy
        • Jun 2015
        • 86
        Thanks guys, appreciate the help. I'm out just now but will check the 12v VCC later today.
        • sickboy
          • Jun 2015
          • 86
          Hi again. Yep, there's 12v on pin1 on UB801. I also tried freezing the chip incase it helped show the chip as the culprit, no change though.
          • R_J
            • 9611
            Did you freeze the chip when the tv was unplugged? I thought you ment freezing the eeprom ic, this is the backlight driver, freezing it won't help
            • sickboy
              • Jun 2015
              • 86
              Yes, frozen with RS freezer spray, waited 30 seconds or so and powered on. Just the same symptoms though.
              I looked through my spare boards (taken from TVs with broken screens) and tried one from a 40 inch version of the same model. Backlights came on but no image on screen - obviously due to the board being for a different screen. But at least it proves my backlights aren't the issue
              • R_J
                • 9611
                That UB801 is the backlight driver ic not the eeprom, so freezing it would not likely do anything.
                Did you try freezing the spi/eeprom chip? I think this board uses a nand chip, mx30LF1G18IC, It might be available for this model
                • sickboy
                  • Jun 2015
                  • 86
                  Ah ok lol. The nand must be on the underside of the board. Will check tomorrow. If it’s an spi 8 pin flash I can change it but a nand chip is beyond my soldering skills ☹️
                  • R_J
                    • 9611
                    The spi would be located at UF1, it's not populated
                    • sickboy
                      • Jun 2015
                      • 86
                      Morning R.J., yeah it's a big nand chip on the underside of the board, I tried giving it a freeze as well but still no results.
                      I may just have to buy a replacement board for this TV I'm guessing, although I'm not sure if it's worth the cost given that it's a basic model with no smart functions.
                        • 12314
                        • U.S.
                        Yes they want too much for this size screen, there's some with make offer, my offer would be half what they are asking at most: https://www.ebay.co.uk/sch/i.html?_f...F5111K&_sop=15
                        • sickboy
                          • Jun 2015
                          • 86
                          Thanks. I managed to get one from EMOS (big UK supplier of used parts). It was advertised for £35 buy-it-now, but I sent an offer of £20 along with a note saying it's just a basic 32" TV and that would be my maximum offer. They accepted 20 mins later. That should be the problem solved, just a pity we weren't able to get down to component level repair on the original board.
                          Thanks for everyone's input though. Have a nice weekend guys.
                            • 12314
                            • U.S.
                            Now that's more like it, good price.
                            • R_J
                              • 9611
                              Was the tv unplugged when you tried spraying the ic? It needs to be unplugged, The ic is read when first plugged in. But that freezing trick usually only works with those 8 pin spi ic's and not the nand
                              You had 12v on UB801 pin1 , you could check pin8,that is the PMM pin that controls the brightness of the backlight
                              • Rictech
                                Panasonic SA-MAX770PU SMPSU board fault....
                                by Rictech
                                Hello everyone. 😀
                                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                There are no devices that have exploded or otherwise show signs...
                                08-26-2024, 01:05 AM
                              • howardc64
                                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                by howardc64
                                • Prior owner tried a replacement main board. No difference.
                                • Samsung 2x red blinking standby LED = panel fault
                                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                07-19-2025, 10:54 PM
                                ESR meter came to the rescue again today with a PLC I/O card fault
                                by sam_sam_sam
                                I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                12-18-2023, 08:17 PM
                              • Agent24
                                What kind of fault causes this image error?
                                by Agent24
                                I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                                The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                                What's the most likely cause of this problem, does anyone know?...
                                09-22-2025, 11:42 PM
                              • cazi1001
                                Strange fault on Lenovo ThinkPad E14 Gen. 2
                                by cazi1001
                                I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                                The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                                On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                                03-24-2024, 04:16 AM
