Vizio E550i-B2 no power, no sound, no LED -- blown IC found
  • aecune
    • Aug 2019
    • 17
    Re: Vizio E550i-B2 no power, no sound, no LED -- blown IC found
    OK I see it now. I was looking for the element from the top-side of the board. Values are:
    R908A - 1.5Ω
    R908B - 1.5Ω
    R908C - 1.5Ω
    • R_J
      • 9520
      Ok, those are ok, It is likely just the shorted ZD909 that is causing the ic not to operate. with the current sense resistors shorted by the zener the ic will likely shut down for protection after a couple cycles.
      • aecune
        • Aug 2019
        • 17
        Thanks a lot for the help so far, R_J and budm. I have one question regarding identifying ZD909; it is marked NZ 4V7D or NZ 4V70--it's hard to distinguish the last letter. Regardless, I cannot find anything online with this information, except, incidentally, another badcaps thread thread with you gentleman in it :-)
        https://www.badcaps.net/forum/showthread.php?p=851050
        Within that thread, budm had the following exchange:
        OP: "Only found 2 bad diodes. zd909 which is a nz4v7d replaced with a nz6v8b"
        budm: "I would out in the same value, they put 4.7V Zener for reason"
        If this is a 4.7V diode, what other specs should I look for in a replacement diode, for example, current, impedance, etc?
        • R_J
          • 9520
          A 4.7v 1 watt zener would be fine. it's not that critical. Its just to protect the ic's source input from any voltage spikes that might occur. The source pin maximum is around 7v
          • aecune
            • Aug 2019
            • 17
            I replaced the zener, but still no dice. Going to recheck all my soldering tomorrow as best as I can, though I'm not 100% sure of which items connect to which, without a wiring diagram for this board. I'll also check voltages on various nodes to see if there are changes in the voltage.
            • aecune
              • Aug 2019
              • 17
              Did more testing of the voltages, as well as checking the resistors again. Also checked continuity.
              1) Found nothing continuous with Pin1 + 3 of IC901. 3 is GND--maybe no issue. 1 is "S", which is source terminal of internal power MOSFET. PDF recommends connecting with a sense resistor to GND--maybe also not an issue.
              edit: Pin 1 and 3 are continuous with an elements closer to the main cap, so soldering is not an issue.
              2) Many of the resistors appear to have no power across them, as their voltages appear identical on both sides.
              3) R804A, which is near the main cap, has 0.2 ohms of resistance. It's marking is 0.068Ω (68mΩ). Maybe a problem. Shown in second uploaded picture.
              4) ZD909 (which has been replaced) is showing no forward voltage again, while connected to the circuit (I know this isn't best way, but it's showing same characteristic as previously replaced diode, unlike the other zeners)
              edit: all voltages are taken with regards to the negative leg of the main cap.
              Also, where and what voltage tells us the cold side is getting powered successfully, and therefore IC901 is repaired?
              • R_J
                • 9520
                R804 is likely good, you need to consider your meter lead resistance whne checking very low value resistors. What is the resistance with your meter probes shorted together
                • aecune
                  • Aug 2019
                  • 17
                  Good question. It's 0.1 ohm. So the measured value of R804 is within a rounding error.
                  Any other ideas? Did you see anything strange with my voltage readings in the picture of my last post?
                  • aecune
                    • Aug 2019
                    • 17
                    I replaced the power board and now my TV is back online. Thanks for the effort, all.
                    I'm going to try to find the root cause by comparing the two. I would still love any assistance if anyone is interested in getting to the root cause here, as the original board is still broken.
                    Edit: Found that C910 and C908 have different values while in circuit, which seems to indicate something nearby is different. This is shown in picture. Capacitors in red have 73uF capacitance in good board, 140uF in bad board.
                    I started looking around the IC when I found that the new PCB has very stable voltage (~18V) on Pin 5 of IC901--while connected--whereas the old board did not (fluctuated 12-24V).
                    I measured many of the diodes and resistors around IC901 and found them to be identical.
                    • R_J
                      • 9520
                      Regarding C908, Have a look at the other side of the board. C910 is a disc cap, likel a few pico farad. Are you checking and comparing both boards voltages in standby?
                      • aecune
                        • Aug 2019
                        • 17
                        Yes, both boards were in standby (power connected, but not turned on).
                        A little bit amusing maybe.. there is no element on the topside at C910. So.. I'm not sure what to think about that.
                        • Digital_Dad
                          DIY'er
                          • Apr 2017
                          • 36
                          • U.S.A.
                          #32
                          Have you figured this out?
                          • dragonwyatt
                            • Jan 2024
                            Greetings all, reviving this thread. I have this same problem. I've attached an image of my failure... We were watching TV and there was a loud POP, the TV died, and then there was the enjoyable smell.
                            I found a repair kit of sorts from shopjimmy . com, but they appear to be out of stock.
                            If the picture there is to be believed, there's IC901, a zener, another diode, and a resistor, but no detail on that page about where the diodes and resistor go...
                            https://www.shopjimmy.com/component-...ower-supplies/
                            Any help would be appreciated, I'd love to repair this and keep it out of the landfill!
                            Thanks in advance!
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • aidanmo
                              Philips 43PUS7506/12 - Loud blown out sound
                              by aidanmo
                              I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                              I thought maybe the speakers got damaged, so I replaced them - no dice.
                              • Using the internal speakers, it always happens.
                              • Using the headphone jack, it never happens.
                              • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                              02-28-2025, 03:13 PM
                            • ggil44
                              Vizio M65-E0 No Picture, No Sound
                              by ggil44
                              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                              09-03-2024, 08:30 PM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
