Samsung UN75F6300AFXZA Left Half of the screen Dark
  • nomoresonys
    • 12269
    • U.S.
    #41
    Re: Samsung UN75F6300AFXZA Left Half of the screen Dark
    you can also test by unhooking the u-cables usually located by the bottom corners and turning on and check display, as mentioned in post #22, sometimes they are not easy to get at, hence trying the tcon ribbon cable removal first, read the whole thread again if needed.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4456
      • Italy - Milan
      #42
      I think it could last much time but some imperfections could be see from one side respect to the other
      • nomoresonys
        • 12269
        • U.S.
        #43
        Originally posted by ewilli10
        Hey folks, great thread. I recently came across this same model with exact same panel symptoms. I haven't dug into it yet, but I'm fully anticipating having to do the side tab removal trick as a last resort. My question is - what is the life expectancy after doing such a procedure? @MilitaryBrat is your TV still working 3 years later? Thanks
        its worth doing if that is what is wrong with the tv, otherwise you just have a tv that is not functional.
        • ewilli10
          • Sep 2017
          Thanks for the advice. I was able to open it up and do some diagnostics over the last couple evenings. The pictures attached is the way I got it. As you can see, its got the discoloration & sluggishness moving right-to-left across the screen like the OP's. The discoloration starts about 1/4 of the way across and gets progressively worse. It produces this interesting "checkerboard" pattern which I assume corresponds to each section that the gold tabs control. Jiggling or pressing on the tab bonds did nothing, none of them appear to be burned or blown, and they seem well connected to the driver board. Just about all of the gold ribbon tabs on the bottom of the screen get extremely hot though. The side tabs on both sides of the screen are cool as a cucumber.
          When doing the u-cable disconnection test (one side at a time), it didn't matter which side got disconnected, my result was always a black screen. I was never able to produce an image on either side by isolating that half.
          Is it safe to assume that BOTH sides of this panel are bad since I cannot generate an image? Is all hope gone? Thanks
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4456
            • Italy - Milan
            #45
            This defect connects to the lack of vgh or vgl signal on one side , the darker one.. sometimes the thin wire bridge trick can fix the thing.. check also youtube for this type of repair
            • nomoresonys
              • 12269
              • U.S.
              #46
              so all the cofs on the side boards look good? could be a bad component or two on the driver board/s, maybe a bad ribbon or lvds cable, maybe clean them and make sure they don't have any bad contacts and are aligned properly. had a tricky bad side cof a while ago, the side of the board thats facing out, the one thats easy to see, you couldnt tell the cof was bad, but when I looked at the other side there was an obvious burnt cof, but on that one I did get a picture when u-cable was disconnected.
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • armoured_smiler
                Panasonic Tx-40cx400b top left half screen not displaying correct
                by armoured_smiler
                Trying to work out if this is TFT problem or TCon issue.
                The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                04-08-2024, 03:40 PM
              • Zelek11
                Panasonic Plasma screen interference on left half of screen
                by Zelek11
                My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                10-14-2022, 04:54 PM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
