Samsung UE55H6200 Sound but no video display
  • Nix125
    • Aug 2019
    • 25
    • Uk
    Good morning all hope someone can help,
    One evening a week ago Our samsung TV screen suddenly went blank but audio was still working. Left for a while then turn off/on power to see it this resolved the issue but issue still persists. Input is not the issue as menu screen is not visible either. Did the flashlight test which failed also. Audio still works but no led back light or video display.
    Please see attachment for picture of the tcon, power board and main board. Before I start randomly changing boards, ect. When powering up the front red LED flashes around 7 times. Can anyone advise on how and what to test next?
    Kind regards
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung UE55H6200 Sound but no video display
    With tv unplugged, unhook cable from powerboard to mainboard, plug tv back into power, see if backlights come on.
    • Nix125
      • Aug 2019
      • 25
      • Uk
      Thanks for the response nomoresonys as soon as I get home I willteat
      Thank you
      • Nix125
        • Aug 2019
        • 25
        • Uk
        Ok so when I disconnect the power board from the main board I can see the LEDs light up from the holes behind. Coincidentally it seems that if I keep the power connect to the main board and disconnect the tcon board the LEDs do light up. What can you make from this?
        Kind regards
        • neilc6
          • Nov 2015
          • 1550
          Disconnect ribbon cables (unplugged) one at a time and see if you get a picture.
          https://www.badcaps.net/forum/showthread.php?t=50646
          • Nix125
            • Aug 2019
            • 25
            • Uk
            Hi neilc6, I've tried disconnecting the ribbon cables one at a time and have the same issue. It seems that as soon as the t con board is connected the leds go out even with no ribbons connected to the LCDs. There are no lights built onto the tcon board. Could it be a faulty tcon board?
            • nomoresonys
              • 12331
              • U.S.
              It is looking like a faulty tcon, I would try one if they're not to expensive, tcon can be tested, how to test can be confusing tho if not clearly marked.
              • Nix125
                • Aug 2019
                • 25
                • Uk
                Thanks for the reply do you have any guidence on how to test?
                • nomoresonys
                  • 12331
                  • U.S.
                  To be honest I have trouble knowing what the voltages should be, haven't had to deal with them very often, well lets see which one you have, what are the first 10 letter/numbers on your white sticker? Should start with bn-96xxx.
                  • Nix125
                    • Aug 2019
                    • 25
                    • Uk
                    Thanks for looking nomoresonys. Take a look at my attachment you should be able to zoom up as its decent resolution?
                    • nomoresonys
                      • 12331
                      • U.S.
                      See the labels vgb 14, vgb13 etc, and the little round copper looking pads, there's like 28 or so, those are test points but I don't know what voltage they should be.
                      • nomoresonys
                        • 12331
                        • U.S.
                        One there that seems to be a match: https://www.ebay.co.uk/itm/5555T10C0...UAAOSw2QtdJ2za
                        • nomoresonys
                          • 12331
                          • U.S.
                          Just in case it can't be fixed, list there, the first one has a bit different numbers think I would skip that one, but from 2 down a ways look like a match, they seem to have a bunch of them, they also have a make offer option: https://www.ebay.co.uk/sch/i.html?_f...vn05.7&_sop=15
                            https://www.badcaps.net/forum/attach...2&d=1566036467
                            Check: with and without ribbon cables between the LCD panel connected. Do not disconnect and re-connect any cables when TV is plugged into the outlet.
                            VGH
                            VCOM
                            V12
                            Does LED3_AVDD light up when TV is turned on?
                            • Nix125
                              • Aug 2019
                              • 25
                              • Uk
                              Hi nomoresonys thanks for the links on ebay I checked them out a few days ago hopefully tcon board will fix the issue. Dudm we tried with and without the lcd connect which made no difference. There is no led on the tcon board?
                              Many thanks
                              • nomoresonys
                                • 12331
                                • U.S.
                                Did you test those three spots in Buds post #14? VGH
                                VCOM
                                V12
                                • Nix125
                                  • Aug 2019
                                  • 25
                                  • Uk
                                  Hey nomoresonys I can see VGHC, VGL and VGB12 on the TCOM board is this the pads to check. I have a multimeter what am I checking for? Thanks
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    Damn if I know, I was trying to learn what they should read myself.
                                    • Nix125
                                      • Aug 2019
                                      • 25
                                      • Uk
                                      �� lol were see if the Tcom board I ordered will fix the tv should arrive late next week.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        good question but probably not important. The reason being, is just measure and post the results. The "wrong voltage" will usually standout... low, high or otherwise. You aren't looking for an absolute value at this point.
                                        further, the labeling isn't going to be "exact" for all set and hence look for things like "VXXX" or so as potential points of interest. As budm has indicated, those that he listed are a good "type" to look for.
                                        • FourRunner
                                          Display issue Samsung TV UA65JS9000W
                                          by FourRunner
                                          I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                          10-03-2024, 07:05 PM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...
                                          09-06-2024, 10:20 PM
