Re: Sony KDL-40W2000 3 LED Blnks Error
Ok Budm I shall try putting the NEG lead of DMM on the Heatsink of the HOT side and remeasure VC1 pin to clarify this, I took your advice to measure from the area you referred to in previous post as I didnt have access from the top of the board I used the point in my pic to show this. I must have misread this and was taking measurement from the Chassis GND and not the HOT side like R_J quotes above my bad I will try sort this out tonight and update my results. Thanks for your help.
I have attached a small illustration to clarify I a going to be taking my measurements from the correct area of the board.
OK, I just dealt with this myself the SONY 3 blink power supply IMMEDIATELY goes into safe mode when the main board is bad. I think he's having issues exactly the same reason I did. the big click then click and 3 blinks, its sending the power supply into safe mode and shutting it down.. when you unplug the power supply from the main board it does NOT turn on anything like most boards.. I was going crazy over this for almost a week..Leave a comment:
Hi Standby pin HAS steady 3.3v with PSU to Mainboard cable connected or disconnected. (CN6200)
I can confirm the standby voltage stays steady at 3.3v.
Measured:
VSEN pin 1 = confirmed 330vdc
VC1 pin 8 = 330vdc
Both measurements taken from hot side after negative leg of the main filter cap for ease of access.
Thanks for your help on and hope these results I have gathered now make more sense.Leave a comment:
Be VERY CAREFUL when working on the hot side some voltages can be DEADLY, just a warning for those following that my not be aware.Leave a comment:
He's using chassis ground not HOT ground to measure the voltage.Leave a comment:
Measured:
VC1 pin 8 = 330vdc
But right now at least we know that 3.3V power supply is steady.Leave a comment:
The request is SIMPLE, just measure the standby pin, if it's not as expected unplug cable from power board to mainboard, then measure again, see if it's as expected. You can also unplug everything from powerboard just plug in power cord and see what you have at standby pin, this will be your starting point.
"I can't get a reading from the IC as it cuts to the error mode too quick."
0V on all the pins?
VSEN cannot be 0V since it is connected to the main filter cap via resistors that has 330VDC in standby.
VC1 will be 0V if PS-ON is not present, VC1 is generated by the 3.3V STBY AUX winding of the 3.3VSTBY SMPS transformer.
Did you us chassis GND of HOT SIDE circuit ground which will be the negative leg of the main filter cap in the hot side.
VC1 pin 8 = 330vdc
Ok, I don't know about every singe one but most powerboards I've messed with when working properly, have a steady as expected standby voltage when testing the board with nothing else connected.Leave a comment:
Thanks for your input nomoresonys I shall give this a go soon as I can.Leave a comment:
Service manual:
https://www.manualslib.com/download/...l-40w2000.html
Error code 3-blink:
3 ) UNREG10.5V, PANEL5V Voltage Trouble (DCALERT
So perform test as RJ suggested.
S.Leave a comment:
The request is SIMPLE, just measure the standby pin, if it's not as expected unplug cable from power board to mainboard, then measure again, see if it's as expected. You can also unplug everything from powerboard just plug in power cord and see what you have at standby pin, this will be your starting point.Last edited by nomoresonys; 08-13-2019, 06:47 AM.Leave a comment:
Hi everyone, sorry about the lack of input was away on a course with my work. Anyway if we disregard the OP part "I have attached a pic of connector CN6200 as I took some measurements from it but no voltages were present with the connector seated or unseated." I had been trying to take measurements when error had tripped the supply, This is where I am at the moment with the TV.
All connection in place and Voltage readings from the CN6200 are present - I can only get these measurements when I apply power and the relay clicks as to try and start the TV up, so I've had to keep doing this to get the readings, when the tv goes into the error mode and as soon as it does I lose all voltages. At one point when measuring the standby voltage I was getting solid 3.3v then it would drop and come back up this was when in error mode.
I have removed the power board and gave it a good visual inspection top and bottom side, no dry solder joints and no cracked / damaged parts or areas of PCB.
I will go through all replies as soon as I can get the time to get the TV opened and measurement took.
Thanks for all the input on this.
S.Leave a comment:
"I can’t get a reading from the IC as it cuts to the error mode too quick."
0V on all the pins?
Did you us chassis GND of HOT SIDE circuit ground which will be the negative leg of the main filter cap in the hot side.Last edited by budm; 08-09-2019, 04:21 PM.Leave a comment:
Check those solder joints on powerboard with a big ass magnifying glass.Leave a comment:
this is the answer
That is what I am trying to find out if the 3.3V STBY is dropping in and out or what, OP said he gets 0V on 3.3V STBY then the main board will not have any power to run it to produce error code if 3.3VSTBY is not present. Trying to get the answer from OP.Leave a comment:
I think he is refering to the fact that there are two operational sections on some of these models, One is for the digital part and one is for the analogue. and they have seperate service menu's. I have seen a kdl46S2000 that will cycle on and off if set to the only hdmi input. It also will not program or receive any digital tuner channels, other than that the analogue part the tv works perfect.
That said, none of the tv will operate if there is no standby voltage.
When the tv quit, what input was it on? You can try disconnecting the flat white cable between the main board and the FEE board (with the card slot) and see if the tv stays on.Last edited by R_J; 08-09-2019, 03:47 PM.Leave a comment:
In your post #8 "Gettting ~240v on both sides of the fuse - What i don't get is I get nothing on the standby 3v3 pin and i have a Red standby LED then goes to green when powered then, when failure occurs and 3 blinks code appears. I monitored pin 5 STBY+3.3V (CN6200) when on standby, green light and when 3 blink error is repeating, still nothing. DMM set too Auto range on VDC = 0.00v "
So the question is, is the 3.3VSTBY always stay at 3.3V or it drops to 0V with or without having main board connected?
So keep meter probes on chassis and 3.3V STBY pin and tell us if it is going up and down or not.Last edited by budm; 08-09-2019, 04:09 PM.Leave a comment:
by AK_777Hi everyone!
I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and... -
by jchonHi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
I found the service manual, which was critical to know where to probe.
https://www.manualslib.com/manual/20...1e-Series.html
With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
Unfortunately the 5-blinks... -
by NicktronicHi all,
I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
Any Sony experts out there that can help??... -
by dumbddI was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led... -
by NicktronicHey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
Thanks!... - Loading...
