Sony XR-55X90J 4 blinks
  • Nicktronic
    • Mar 2023
    • 247
    Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
    Thanks!
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Look for nicks tvs video on YouTube where he takes out the BL err pin and grounds it to the chassis. Maybe you'll find the problem goes away and or you can see a dead led in the set.
    ​​​​​Need a closer picture on the legend for PSU. This isn't a OLED is it?
    • Nicktronic
      • Mar 2023
      • 247
      It's not an OLED. Tried what you/Nick's suggested, i grounded out the BL-ERR pin (pin 1 on my power supply board), but no luck. I pulled pin 1 wire from the connector on the power supply board and grounded it to chassis with a jumper. Originally, I saw that when the TV fails, the BL-ERR jumps up in voltage, but doesn't latch. So don't think it's my backlights.....or at least not the same problem as in the video.
      • Nicktronic
        • Mar 2023
        • 247
        Close up of the power board connector pinout
        • lotas
          • Jan 2016
          • 4880
          • Russia
          4x - code error
          • Nicktronic
            • Mar 2023
            • 247
            Ok, is there a troubleshooting procedure? Looks like T-Con according to your attachment. What do you mean by code error? Software?
            • lotas
              • Jan 2016
              • 4880
              • Russia
              The chassis is the same as yours, here is the service manual and the procedure for dealing with errors
              https://www.manualslib.com/manual/20...page=38#manual
              • Nicktronic
                • Mar 2023
                • 247
                Ok, so the BE_LD_RDY (CL5223) voltage was low, so I guess it's the Main Board since it's not an OLED and I already replaced the Local Dimming board?
                • jason123
                  Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                  by jason123
                  Hi there,
                  I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                  So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                  I see 2 posts that are relevant:
                  https://www.badcaps.net/forum/troubl...j-oled-5-blink
                  https://www.badcaps.net/forum/troubl...g-hardware-dev...
                  10-29-2025, 02:01 PM
                • matwan
                  Sony XR-55X90J 5 blinks
                  by matwan
                  I have problem with SONY 55X90J. After several check status is as below;
                  1. Running power board as stand alone:
                  TCON_12V =~ 12.6V
                  EVDD V On Max 24V= 19V.
                  2.
                  Running power board with TCON as stand alone:
                  Effect as below, attched.
                  3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                  "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                  Best regards....
                  09-28-2025, 04:26 AM
                • GoodCapDude
                  Sony XBR-75X940E intermittent 6 blinks error code
                  by GoodCapDude
                  Hi everyone. First post on Badcaps!
                  I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                  09-20-2025, 06:07 AM
                • AK_777
                  Sony KD-65A1 Repair – 4 Red Blinks Error
                  by AK_777
                  Hi everyone!
                  I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                  Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                  02-20-2025, 04:15 PM
                • jchon
                  Sony A1e 5-blinks help
                  by jchon
                  Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                  I found the service manual, which was critical to know where to probe.
                  https://www.manualslib.com/manual/20...1e-Series.html
                  With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                  Unfortunately the 5-blinks...
                  06-28-2023, 11:52 AM
