Samsung un46B6000 picture issue after TCON change
  • Brucetafer
    • Jun 2018
    • 133
    the TCON board was bad in this unit and was super white and faded out badly, So i changed it with another "known working" on eBay, and it works perfect for a couple seconds then fades out, and then resets itself as you can see in the pictures.. all the voltages on the power supply are pefect, LEDS are drawing the correct current and all the menu, sound, inputs work fine.
  • Diah
    • Feb 2013
    • 6399
    Re: Samsung un46B6000 picture issue after TCON change
    reset samy as hard rest from service menu (not from setting menu )... so all driver will register the new quest hardware you added
    • Brucetafer
      • Jun 2018
      • 133
      It refreshed again, then worked solid for 10 minutes, then did this.. ugh! I just want a tv for my bathroom!!! this one is only 1 inch thick...
        • 12206
        • U.S.
        Check your little caps on tcon, check them for low ohms or shorts, tv unplugged of course.
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • Kjell
          Samsung Series 9 - BIOS issue
          by Kjell
          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
          08-01-2025, 09:15 AM
          09-07-2024, 05:50 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
