Sharp Aquos LC -70LE640U
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I got a freebee that a guy wanted gone out back of his pickup today.I thought it was total write off as it was face up in box of truck and it was raining all morning.I dried it out for couple days and now the problem is showing itself.Screen is dark on one side and video like in slow motion.Seems i have to remove tabs on one side or both?
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp Aquos LC -70LE640U
    well you can't remove tabs on BOTH sides unless you just want to watch a blank screen, as you need tabs on at least one side.
    From the pictures, I would say there is some cabling disconnected... have you looked at the back of the set?
    • charlie555
      • Feb 2018
      • 76
      • usa
      Do this disconnect one side of the ribbon cables from the lower side of the tcon then turn on.one side will come on and check for image. Do the same thing for the other side also . Unplug power when switching sides.
      • sputnikoff
        • Feb 2016
        • 203
        • canada
        I had a spare t-con board so i installed it to no avail set would not power up.I reinstalled original t-con and re seated sides and set worked perfect.I came back after running and errand and its distorted again back square 1.
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          Went out and powered down set for while and screen came back normal waited awhile and screen started to distort and go dark.I had hunch so i replaced the tcon board again and screen came on this time.gonna run it all night and see what happens.The chips on sides all looked ok and felt cool to touch.
          • charlie555
            • Feb 2018
            • 76
            • usa
            K, all were cool? Usually in my experience if I replace a tcon and messes up again I find a hot driver tab. It shorting-out the tcon board.
            • charlie555
              • Feb 2018
              • 76
              • usa
              Check your driver boards on the bottom one. Just press them while it’s on and see if any changes occur.
              • sputnikoff
                • Feb 2016
                • 203
                • canada
                Thanks charlie for tips.I checked it this morning and unit is running perfectly.The only issue is there is a spot in right top corner and in couple of other places very hard notice in other places.I have suspicion it may be residue left by water as it was left outside in rain.I'm glad i never jumped the gun and cut those side tabs.Looks so far as t-con was issue.
                • sputnikoff
                  • Feb 2016
                  • 203
                  • canada
                  Here is another pic of smaller spot but that seemed to have disappeared this morning.
                  • Diah
                    • Feb 2013
                    • 6339
                    TV under rain for days.. the wet going over all either the sheets behind the LCD. via working it will dry.. but it may left fleck. as this point need to take it screen apart and clean them. other wise i would leave it so for my weakness eyes.
                    • sputnikoff
                      • Feb 2016
                      • 203
                      • canada
                      Thanks Diah yes one spot has pretty well gone and other seems to be fading.I have let it sit in dry area for another while with set on.
                      • sputnikoff
                        • Feb 2016
                        • 203
                        • canada
                        Diah the board only lasted a week back to same picture.I guess i will have cut ribbons on one side after all.
                        • budwich
                          • Jul 2015
                          • 3097
                          I wouldn't do any "cutting" just yet. disconnect the small cable in the bottom corner... there is one on each side. Check what the result is on the picture when one is disconnected. If your spots don't go away, it is likely that cutting any side tabs is going to help the situation as the problem is more likely associated with the tabs along the bottom.
                          • sputnikoff
                            • Feb 2016
                            • 203
                            • canada
                            Yes budwich that was my fear.I will give it a try.
                            • charlie555
                              • Feb 2018
                              • 76
                              • usa
                              Yes removed one side got this now. Don't know if I pull the bottom what it will do.
                              • Rozp
                                70LE660U dark cloud or black screen with sound.
                                by Rozp
                                Hello Everyone,
                                This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                08-29-2023, 05:25 PM
                              • sefoster
                                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                by sefoster
                                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                11-20-2022, 09:29 AM
                              • jonah1024
                                Sharp Aquos LC-40UG7252E LCD TV burn in?
                                by jonah1024
                                Hello!
                                I'm a few days old into this TV screens repair universe so please bear with me.
                                Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                - I did a factory reset as well...
                                07-16-2024, 04:23 AM
                              • klassic
                                Sharp Aquos LC-60LE635E three blinks
                                by klassic
                                Hi community,
                                I will describe my problem with a TV in those short following terms to be the most precise :
                                What i have :
                                power board DPS-162KP-1
                                main logic board QPWBXF733WJN2
                                symptoms :
                                white led light logo at startup,
                                after 2 minutes, blinking 3 times a row, repeating
                                no backlight (and apparently no picture, checked panel with flashlight)
                                no startup sound
                                powerboard investigations :
                                1-2 PNL : 0v
                                3-4 GND
                                5-6-7-8 UR : 13.15v
                                9-10-11-12...
                                10-24-2023, 01:39 PM
                              • scubacamper
                                Sharp Aquos LC-70C6400U Half Screen Dark
                                by scubacamper
                                I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                05-03-2025, 12:19 PM
