Capacitor replacement of TREAMCAST internal power transformer
  • gtsamour
    • Jul 2019
    • 11
    • Greece
    so I'm a proud owner of a Treamcast, the latest black model with the PSone 4:3 screen.
    I opened it up and replaced the laser lens because the drive had a difficult time reading discs (mosly cd-r) and now its all good.
    I noticed though that the caps on the internal power transformer was a crappy brand (what a surprise since the Treamcast is a Chinese knockoff).
    The brand of the caps are Aishi of the CD81 kind which is supposed to be "low leakage", I'm obviously talking about DC leakage. There was only one Nippon cap, probably for the others to rub off (lol).
    The thing is I only have regular good brand caps (panasonic, Nichicon, Elna).
    Since this isn't a switching PSU but a tranformer (takes 12V DC and gives 12V, 5V and 3.3V), do the caps need to be "low leakage" or can I use the good brand standard type caps that I already have? (with the right capaciance and voltage rating ofcourse).
    Thanks for any insight.
    • 31285
    Re: Capacitor replacement of TREAMCAST internal power transformer
    if it's not a high frequency supply then dont bother, aishi arent that bad.
    • gtsamour
      • Jul 2019
      • 11
      • Greece
      Well a Treamcast is estimated to cost around 500$ right now because its rare. I would like to make it last, who knows in the future it's value could go way higher so I would like to put some really good stuff caps in there if "low leakage" isn't an issue and I can install regular ones.
      What is weird is that the same low leakage caps (CD81) were also present in the sound amplification board in which even me could tell weren't necessary to be low leakage. I replaced those already but I don't know about the ones in the transformer cirquit thats why I'm asking.
      And from what I read in this forum, Aishi caps ain't that good...
        • 31285
        i wouldnt use them in high frequency, high ripple stuff,
        but i'v only seen them fail in very hot places.
        VERY hot - inside lamp ballasts that run 10-16 hours a day.
          It does have Buck switching regulators, LM2576-5V and LM2576-Adj.
          https://cdn.badcaps-static.com/pdfs/...8b6f64a899.pdf
          • gtsamour
            • Jul 2019
            • 11
            • Greece
            OK, so? Help me here... do the caps need to be low leakage or not? Because CD81 caps aren't low ESR or anything, I looked it up.
              • 31285
              if it's a switching design then they must be low ESR.
              otherwise they heat up internally and fail faster.
              • gtsamour
                • Jul 2019
                • 11
                • Greece
                Well they're not.... I can't find a specs pdf for Aishi CD81 caps, only mentionings in listings and the only thing that describes CD81 is "low leakage".
                Something tells me they're destined to fail.... soon.
                Also, CD81 seems to be a general code for low current leakage, it exists as a code on other brands too.
                The closest thing I found...
                https://cdn.badcaps-static.com/pdfs/...8ea1037520.pdf
                  • 31285
                  any other markings on the cap?
                  • gtsamour
                    • Jul 2019
                    • 11
                    • Greece
                    Besides CD81 absolutely nothing.
                      • 31285
                      well if you use low esr - dont go overboard.
                      something like rubycon YXG/J or ZL, or panasonic FC would be the limit for how low the esr should get.
                      • gtsamour
                        • Jul 2019
                        • 11
                        • Greece
                        Thank you for your helpfull info
                        • lti
                          • May 2011
                          • 2558
                          Nippon Chemi-Con doesn't make a BF series. I saw those in an EEVblog thread a while back, and the actual brand was next to the date code.
                          • gtsamour
                            • Jul 2019
                            • 11
                            • Greece
                            So this one is bogus? I see lots of BF "Nippon" on ebay but I can't find any official specs sheet for it so you might be right. Does this one need to be low ESR too? I think not since the current its on is DC.
                              • 31285
                              nippon is japanese for japan.
                              chemicon is abreviated to ncc.
                              (nippon-chemi-con)
                              • gtsamour
                                • Jul 2019
                                • 11
                                • Greece
                                Recap done, all low ESR caps are Panasonic FC Series. New laser lens and a new socket with a removable recharchable battery too
                                  • Jul 2011
                                  • 6070
                                  Here is my rule of thumb
                                  If the power supply has any type switching regulator ic chip of any type I automatically change all the capacitor in it except maybe the main capacitor but if shows any kind of leaking or it is swollen in anyway it might get replaced anyway
                                  If over 5 years old and you are using 8 to 10 hours to 24 hours a day then for sure recap the board
                                  • learnmore
                                    Help choosing replacement transformer for Levoit 600S SMPS
                                    by learnmore
                                    Hello Community,
                                    I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                    Peace
                                    LM...
                                    11-04-2025, 09:35 AM
                                  • unimatrix93
                                    Replacement transformer for Samsung fridge
                                    by unimatrix93
                                    Dear forum
                                    My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                    No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                    The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                    My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                    07-14-2025, 02:16 AM
                                  • the_rem
                                    Unknown transformer : how to find a good replacement part ?
                                    by the_rem
                                    Hello guys,
                                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                    04-23-2025, 01:48 AM
                                  • double_DD
                                    Transformer replacement for a dead coffee machine
                                    by double_DD
                                    Hi guys,
                                    I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                                    Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                                    If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                                    My other ideas:
                                    - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                                    - to buy...
                                    06-23-2025, 05:43 AM
                                  • JDC
                                    Sony STR-DE697 - Bad Transformer. Replacement? Unknown Value!
                                    by JDC
                                    Got a Sony STR-DE697 with a bad power transformer (1-435-281-11). This will be my second receiver with a bad transformer; the first I was able to find a direct replacement off ebay. With this one, nothing has been found except for an old ebay listing for the sub board itself.
                                    Tried to find a service manual to determine the transformer's specs but to no avail. Tried similar models with the same model transformer but no go.
                                    So....
                                    1) How does one determine a transformer's specs (input, output) if there is no information about it available? Are there...
                                    10-04-2020, 12:36 PM
