Hi everyone, this TV has vertical lines, I tried to touch the flat on the panel and on the t-con but it doesn't change anything, do you think it is a panel problem and therefore not repairable or the defective t-con? I attach photo of the defect
tv led samsung UE46F8000SZ vertical lines
Re: tv led samsung UE46F8000SZ vertical lines
What is the history of the TV? The problem just started by itself?Never stop learning
Originally posted by tvzmaj View PostWhat is the label on the panel?
Inspect the bottom of the panel. Traces of oxidation remain if it is washed with liquid. 50% of the chances are to fix it with a alcohol, microscope or magnifying glass.
What kind of alcool is used for these cases?
I've seen videos where they replace the flat between t-con and display, how are they electrically connected and which glue is used?Last edited by poweron; 06-26-2019, 04:19 PM.
