Samsung UN40KU6300FXZA ver FA01 main board replacement
  • k9rulz
    • Jun 2019
    • 4
    I'm looking to replace the main board on this TV. I've ordered the parts. However, when I look at the main board there are no screws for removing it, unlike other TVs (or on the power board). It looks like there are tabs? where the screws should be? do they just need to be pushed in to unlock it from the frame?
    any thoughts would help! thanks!
    sorry! pics now attached
    Re: Samsung UN40KU6300FXZA ver FA01 main board replacement
    Pictures?
    • k9rulz
      • Jun 2019
      • 4
      attached pics. thanks!
      • R_J
        • 9627
        If you lift the board slightly to clear the metal stop, the board should slide to be removed. The silver metal clips remain with the board.
        • k9rulz
          • Jun 2019
          • 4
          thanks! i just didnt want to force anything and break off something I'd need for the new board.
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • mrautom8
            Samsung TV UN75H6350AFXZC main board schematics?
            by mrautom8
            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
            While relay is on, all voltage rails are present and steady (scoped) on main board.
            I love a good logic puzzle but getting lost without any schematics.
            No shorts on ANY capacitor main board.
            Thermal camera shows 3.3V inductor getting warm instantly but...
            10-19-2025, 06:32 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • PMan976
            Samsung Main board replacement-bn94-07217N
            by PMan976
            I have a Samsung TV that has a bn94-07217N main board. I am having a hard time finding the N version of the board but I can find Ver K and Ver F boards. Does anyone know what the differences are and whether they are interchangeable?
            I was told that the N ver is a Canadian version.
            If anyone has any information on the Samsung versions it would be appreciated.
            06-13-2023, 03:02 PM
          • Lee M.
            Samsung UN75RU8000FXZA bad main board?
            by Lee M.
            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
            11-08-2023, 07:46 PM
