LG 55EC930V power supply problem
  • R_J
    • Jun 2012
    • 9632
    Re: LG 55EC930V power supply problem
    Originally posted by xmandarkx
    chassis ground for the relay coil
    This is wrong, one side of the coil is connected to HOT ground, You need to use HOT ground to measure the coil voltage on this power supply, using cold ground is why you measured 170v
    Your power supply is working according to your voltage readings (+12,+24 etc.) If the inrush relay is not clicking I suspect whoever opened it has damaged it. Check the coil resistance, it should be around 200~300Ω
    • xmandarkx
      • Dec 2013
      • 54
      after close inspection i seen the relay winding's are damaged/broken and getting 80Ω
      would that be the cause for it not powering the screen up?
      • xmandarkx
        • Dec 2013
        • 54
        thanks for the help so far, i will get the relay replaced and see what happens next.
        • R_J
          • Jun 2012
          • 9632
          80Ω might be ok, remove the relay and check it again. What is the number on the relay and what is its coil voltage?
          • xmandarkx
            • Dec 2013
            • 54
            this is the relay
            https://uk.farnell.com/oeg-te-connec...10a/dp/1892000
            i wont be able to remove the relay until i get to work tomorrow. hopefully i will have a replacement for it there too
            • R_J
              • Jun 2012
              • 9632
              80Ω is too low for the coil resistance, it should be 267Ω, so if its not the coil it could be something else in the circuit causing the lower resistance
              Relay# SDT-S-112DMR 12volt
              • xmandarkx
                • Dec 2013
                • 54
                the coil is definitely broken, i have an end and loose wires!
                i will get it changed over and see what that does. if i dont have one at work ill get it ordered and will report back.
                • xmandarkx
                  • Dec 2013
                  • 54
                  the relay has been replaced but the only thing its doing new is clicking when i power it on, still no screen coming on
                  • R_J
                    • Jun 2012
                    • 9632
                    What do you mean clicking, when the tv is turned ON the relay should click ONCE. I don't think the problem is with the power supply, It is likely with the t-con, panel or main board
                    Have you checked the other threads for this model?
                    • xmandarkx
                      • Dec 2013
                      • 54
                      yeah it clicks once when the power button is pressed, and again when is turned off.
                      ive not checked the other threads as i was lead to believe it was just a power board fault.
                      can you recommend any threads that may help or should i just have a search?
                      • xmandarkx
                        • Dec 2013
                        • 54
                        ive just noticed a heatsink type thing on the main board and it is really hot to the touch, i think that may be the area i need to look at first
                        • R_J
                          • Jun 2012
                          • 9632
                          OK that is normal, when the tv is turned ON the relay shorts out the inrush thermistor, thats all it does. When the tv is turned OFF the relay opens and the power supply goes to standby and only a small amount of current flows through the thermistor to maintain the standby voltage.
                          Check this thread:
                          https://www.badcaps.net/forum/showth...light=55EC930V
                          This thread has a service manual and a training manual on how to test things
                          • perrier
                            • Aug 2021
                            • Espagne
                            #73
                            Hello, can you give me the references of the transistors Q151 and Q153 and the value of the resistor R174. Thanks in advance
                              03-31-2024, 02:12 PM
                              07-01-2024, 06:34 AM
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
                            • shamsudeen
                              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                              by shamsudeen
                              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                              i know that in linear power supply the noise will be very low comparing to SMPS supply....
                              07-19-2025, 07:14 AM
