Le40c750r2k video glitches and TV restarts after board replacement
  • Kairi
    • Nov 2013
    • 51
    Hi guys,
    Me again with the troublesome Samsung LE46C750R2K I picked up from the street. So I installed everything into the TV tonight and held my breath as I plugged the system into the T-Con. I breathed a sigh of relieve when the display show a picture and didn't blow up on me. It ran for a little bit before it started it glitch out on me. Occasionally the speakers will buzz a little, picture will have artefacts and sometimes the picture would freeze together with the sound before the TV tries to reboot itself. At times it fails to reboot and I have to physically pull the plug to cut power. However most times, TV would work for hours on end without problem.
    I made videos of this happening. The picture froze, the TV tried to unsuccessfully restart before I physically cut the power and had to repeat a few times before it restarted but still glitch out
    https://www.youtube.com/watch?v=mAhXk9hueKQ
    Any idea about this problem? I hate to think that I'm supplied a faulty main board. How likely is this to be a software issue or indeed a connector issue? I'm using existing interconnect cables which lived through a faulty power board that took out the main board. I don't see any burn marks on any of the ribbon cables but I cannot see the inside the tiny holes on the connector for the wire between the power and main board.
  • nomoresonys
    • 12330
    • U.S.
    Re: Le40c750r2k video glitches and TV restarts after board replacement
    Same tv right, you don't need a new thread for same tv, just use the other one, 2 threads on one tv is confusing and pretty much a no no here.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • boosti45
      Macbook pro logic board replacement parts quesion
      by boosti45
      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
      08-21-2024, 05:23 AM
    • tuner2000i
      Philips 65PUS8518/12 distorted image after main board replacement
      by tuner2000i
      hello everyone,
      I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
      The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
      07-15-2025, 01:15 PM
    • Cvrado
      Led TV Board Replacement, same part number and model, different size
      by Cvrado
      Hello my friends!
      I have a question that I think you can answer and help me with!
      I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
      So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
      My concern is that the board won't draw enough voltage to the bac...
      03-02-2024, 05:05 PM
    • snipersquad100
      Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
      by snipersquad100
      I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
      So far, I’ve checked the following:
      • The mains is reaching the transformer
      • Transformer outputs ~15-20 V AC
      • Bridge rectifier outputs ~15-20 V DC
      • All fuses test OK
      • The on/off button signal reaches the PCB connector
      Despite this, the unit does not power up at all.
      Inside, I’ve identified some of the ICs:
      • ST7317 (appears to be an LCD driver, not the main MCU)
      • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
      • Markings like FS1235, unknown IC
      • Board number:
      09-01-2025, 10:57 AM
