LG 60PK750 Plasma loud buzzing blown panel?
  • corellian
    • Apr 2019
    • 6
    Guys and gals,
    basically I'd like to know if it's possible to electrically kill your plasma panel removing internal cabling with it still connected to mains? It's a PDP3R10000 panel btw.
    BACKGROUND
    This unit was working except for the HDMI ports. I confirmed again via disconnecting LVDS and jumpering test points on Control board - test image displayed fine.
    Upon starting to disconnect the main board in an attempt to reflow the BGA chip, I disconnected the cable coming for the PSU board to the mainboard as shown in the pic. To my surprise (not realizing mains power was still connected) the TV turned itself on but with a loudish buzzing.
    I unplugged the mains and didnt worry about it for the time being. After I did a dodgy reflow effort with flux/heatgun, put the mainboard back in and connected everything back up the same buzzing continues and theres no image. Even when trying the test mode!
    The buzzing is not localized to any area but seems to be everywhere. The troubleshooting I've tried is tightening every earth screw and disconnecting Z and Y-sus. With the YSUS disconnected the buzzing goes away but that's probably due to the panel not being energized?
    I don't mind if the panel is fried, at least then I can scavenge the other boards (except for mainboard) and move on to my next learning experience!
  • Unspun01
    • Jun 2011
    • 341
    Re: LG 60PK750 Plasma loud buzzing blown panel?
    Why would you suspect a damaged panel?
    It is more likely that you damaged the Y-Sustain board by plugging/unplugging live. Test for shorts on any heatsink mounted IGBTs or MOSFETs.
    Could be a bad YDRV board (upper or lower) that is shorted and the YSUS is laboring to supply the short and then you get that buzzing until protection shuts the TV down.
    • corellian
      • Apr 2019
      • 6
      Thanks for your post Unspun01.
      I was thinking a panel issues because I could not localize the source of the buzzing. However, upon a quick check disconnecting YSUS from top and bottom Y buffers the buzz remained. Only with the YSUS d/c the buzz goes away. Protection isnt kicking in as the unit isnt turning itself off.
      I will pull YSUS and check for shorts, cold solder joints etc., when I get home tonight.
      • corellian
        • Apr 2019
        • 6
        I was wrong about disconnecting the YSUS makes the buzzing go away. Only by disconnecting Y and Z-sustain does the buzzing go away. As this video demonstrates.
        https://1drv.ms/v/s!At2_QJcZ3njMjiDSnw3FtlNklpwb
        • corellian
          • Apr 2019
          • 6
          I gave up on finding this fault (no picture, loud buzzing). Stripped the unit of its boards and tossed the panel.
          For the record i couldn’t find any shorts in the YSUS and all voltages from PSU were normal and it wasn’t shutting down into protection. There was just a loud buzzing even when the Z and Y sustain was disconnected from the buffers (so not a panel issue). The loud buzzing went away when disconnecting signal cable between control board and YSUS, so assumed there was a fault in either of those. Couldn’t find it in the YSUS (or PSU) and i thought I found a bad cap in CRTL but by pulling it out to test I ripped a pad. The cap tested fine out of circuit so thats when I chucked in the towel!
          • reessi
            Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
            by reessi
            The pics are off the other really long thread as they are much clearer than my phone will do.
            The fault:
            In standby there is no buzzing.
            After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
            It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
            If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
            I have checked every single cap on the psu and logic board by un-soldering...
            07-05-2020, 05:23 AM
          • aidanmo
            Philips 43PUS7506/12 - Loud blown out sound
            by aidanmo
            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
            I thought maybe the speakers got damaged, so I replaced them - no dice.
            • Using the internal speakers, it always happens.
            • Using the headphone jack, it never happens.
            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
            02-28-2025, 03:13 PM
          • notallbad
            Samsung 50" Plasma PS50C450B1W humming/buzzing
            by notallbad
            PSU : Bn44-00414A
            y-main : LJ41-08458A
            z-main : LJ-41-08457A
            T-con : LJ92-01705
            Main : BN41-01361C
            Don't seem to be able to track down where the buzz/hum is coming from on the X and Y main boards. Its more audible on the Y board. Possibly an acceptable level coming from the X board once the rear cover is back on.
            Resoldered joints, found a few that looked like they needed it. Checked caps which seem ok on the X/Y and psu.
            In standby theres no hum/buzz, only when its switched on. Turning the brightness up makes no difference to the...
            07-22-2022, 07:37 AM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • swerg
            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
            by swerg
            Hey everyone,
            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
            06-06-2024, 03:39 PM
